Brake Problems- No one knows :(RC_Racer 06-30-2003, 07:55 PM Alrighty, I'm new to this board, site and such and I'm actually at the end of the line. My 1995 Bonneville, was purchased with brake problems, and i've invested 500 bucks into them and the same problem keeps occuring. Problem 1: I often lose brake pressure, meaning the brakes will suddenly give out and go to completely to the floor, or midway, and pressure will not build up. Problem 2: While driving, at random times the wheels will lock up, the only way to notice is a sudden drop in speed while driving. The brakes get stuck in and its impossible to push down to stop. If I continue to drive, to a safe area to pull over or to my home, smoke pours out, the wheels get red hot, and The rorters have actually caught on fire ;/ -------------- When my brakes first lost pressure, I went to the local mechanic and got a new master cylinder. All was fine for a while until Problem2 came up. The mechanic tried several things but the problem kept reoccuring. MY ABS light was on so I had ended up replacing a wheel sensor, front passenger side. After replacing it, the problem went away. Soon however, Problem 1 reocurred a month later, with no pressure at all in my brakes. I ended replacing the master cylinder, and the problem was solved. however, a week after, problem2, the wheel locking up, occured again. This time it was in the front driver side. I took it in to MIDAS, being tired of the same Backyard Mechanic assuming what the problem was. Midas had no idea what the problem was, but assumed I needed new Caliper and Rorter in the driver side. After replacing the Caliper and Rorter on teh driver side, front, everything seemed fine, but the next day, problem2 reared its ugly head, though this time, with the passenger side. I thought perhaps replacing calipers and rorters on the passenger side would fix it, but Midas and my local Mechanic both agree that would have nothing to do with it. Ty for listening to my problem and perhaps any suggestions people can make would help greatly. R-C_Racer - Signing Out :icesangel trsmith 07-06-2003, 11:08 PM In the long run you'll spend more money on local mechanics and franchises such as Midas or Pep Boys than if you had taken the car to a GM dealer who employ trained and certified GM mechanics. I realize the temptation to get off cheap is tempting, but when dealing with a major issue such as your brakes leave it the real pros. tman 07-07-2003, 01:21 PM I agree. Flatrater 07-07-2003, 10:35 PM Originally posted by trsmith In the long run you'll spend more money on local mechanics and franchises such as Midas or Pep Boys than if you had taken the car to a GM dealer who employ trained and certified GM mechanics. I realize the temptation to get off cheap is tempting, but when dealing with a major issue such as your brakes leave it the real pros. Thank you for that! Your a man after my own heart! mattcp67 08-11-2003, 05:35 AM Dealerships will seem to be more expensive -- but in the long run they will save you time and money. I took this from MSN Carpoint for your model year in the used car reliability rating area. Occasional problems on this vehicle are failures of the Antilock Brake System (ABS) Pressure Modulator Valve (PMV) and the ABS Relay.The cost to repair the ABS PMV is estimated at $474.00 for parts and $117.00 for labor.The cost to repair the ABS Relay is estimated at $12.00 for parts and $26.00 for labor.All prices are estimates based on $65 per flat rate hour and do not include diagnostic time or any applicable sales tax. Flatrater 08-11-2003, 07:30 PM Take me for example in the amount of training I have!! I am a master ASE tech I have me L1 cert And here is a list of my GM training!! Who would you want fixing your car?? This is not to blow my own horn but to show you what we have to do to keep current!! ASEBOD05 BODY: MECHANICAL AND ELECTRICAL COMPONENTS ASEAUTL1 AUTO: ADVANCED ENGINE PERFORMANCE SPECIALIST ASEAUT04 AUTO: SUSPENSION & STEERING ASEAUT05 AUTO: BRAKES ASEAUT06 AUTO: ELECTRICAL SYSTEMS ASEAUT07 AUTO: HEATING & AIR CONDITIONING ASEAUT02 AUTO: AUTOMATIC TRANS/TRANSAXLE ASEAUT03 AUTO: MANUAL DRIVETRAIN & AXLES ASEAUT01 AUTO: ENGINE REPAIR ASEAUT08 AUTO: ENGINE PERFORMANCE Course__________Title 11044.00W-R2 Introduction to Air Conditioning 17041.30W 4T80-E Automatic Transaxle 10270.02D SKH Seminar Feb. 2003 Emerging Issues 17340.12D Allison LCT 1000 Automatic Transmission Diagnostic Issues and Procedures 17041.32W 4T65-E Automatic Transaxle 17041.27W 4L60-E Automatic Transmission 17041.29W 4L80-E Automatic Transmission 17041.30W 4T80-E Automatic Transaxle 10270.05D SKH Seminar May 2003 Emerging Issues 16045.21D Diesel Engine Performance 2001 17340.12D Allison LCT 1000 Automatic Transmission Diagnostic Issues and Procedures 11045.10H Advanced HVAC Systems Diagnostics 10270.04D SKH Seminar Apr. 2003 Emerging Issues 10270.03D SKH Seminar Mar. 2003 Emerging Issues 16044.11D1 GM Powertrain Performance - Part 1 16044.11D2 GM Powertrain Performance - Part 2 16044.11D3 GM Powertrain Performance - Part 3 16044.11H GM Powertrain Performance 16044.09D GM Powertrain Performance Complementary Course 16044.11W1 GM Powertrain Performance - Part 1 16044.11W2 GM Powertrain Performance - Part 2 16044.11W3 GM Powertrain Performance - Part 3 10250.25D 2.2L L61 Engine Technology Close-Up Seminar 10250.21D Oldsmobile/ Buick New Model Features - April 2001 16043.50D Engine Mechanical Diagnosis & Measurement 10270.01D SKH Seminar Jan. 2003 Emerging Issues 16043.45D Engine Mechanical Diagnosis and Measurement 16043.50W Engine Mechanical Diagnosis & Measurement 22043.25W Structural Damage Analysis and Correction 10270.01D SKH Seminar Jan. 2003 Emerging Issues 16040.02W-R2 OBD II 15040.01V Brake Pulsation Due to Lateral Runout 16340.16V Duramax 6600 Update: Service Issues 16040.02T1 OBD II TECHAssist 22048.30H GM Supplemental Restraint System 14043.11W Four Wheel Drive Systems 14041.10W-R2 Rear Axle and Propeller Shaft 19040.20D1 OnStar® Gen 2,3 & 4 Diagnosis and Repair 10250.17D Oct. 2001 Technology Close-Up Service Know-How Seminar - OnStar 19040.20D2 OnStar® Gen 2,3 & 4 Diagnosis and Repair 15045.10W-R2 Foundation Brakes/ABS Systems Service 10041.00W SI Overview 17340.11V Allison LCT 1000 Automatic Transmission Part 2: Diagnosis, Removal & Installation 17340.10V Allison LCT 1000 Automatic Transmission Part 1: Overview & Operation 14040.01V AWD/4WD Diagnosis 010864011 Technical Service Bulletin (TSB) Replace Power Window Motor 16340.30D 4200 Camshaft Position Actuator System Operation & Diagnosis 22048.30W GM Supplemental Restraint Systems 19047.03W3 Entertainment Systems 11045.05V ACR 2000 Familiarization 16041.01W-R2 Battery, Charging, & Starting 19040.01V OnStar VS-P and VS-3B Communication Systems Diagnosis and Repair 98083.01 Electrical Principles and Diagnostics (GMICT/Med. Duty) 96088.15 Tech 2 (GMICT/Med. Duty) 16043.50H Engine Mechanical Diagnosis & Measurement 13044.10H Electronic Suspension Systems 19040.01V OnStar VS-P and VS-3B Communication Systems Diagnosis and Repair 16040.10V Engine Performance Issues 17041.26W 4T40-E Automatic Transaxle 17043.20W NV 4500 Manual Transmission 13041.20D Rear Wheel Steering (Quadrasteer) 13044.10W Electronic Suspension Systems 18044.16W Body Control Systems 10240.20V F-Car Service Issues 10240.20V F-Car Service Issues 18043.01W-R2 Electrical/Electronics Stage 1 18043.02W-R2 Electrical/Electronics Stage 2 18043.03W-R2 Electrical/Electronics Stage 3 18044.16H Body Control Systems 15045.20W Bosch Series 5 ABS/TCS 17043.10W NV 3500 Manual Transmission 18043.16W Body Controller 15045.30W 4WAL ABS 15045.40W Delphi Chassis Series VI and DBC 7 ABS/TCS 17040.10V TCC Diagnostic Tips 13041.10W Steering Service 13041.10W Steering Service 10040.00W SI 2000 Overview 22048.22W GM Air Bag Systems 19047.06W Security Systems 19047.03W1 Entertainment Systems 19047.03W2 Entertainment Systems 16240.30W 1997 - 2002 Bi Fuel Vehicles: Mixer-Based Fuel Systems 16045.21W Diesel Engine Performance 2001 11045.10W Advanced HVAC System Diagnosis 19047.03W2 Entertainment Systems 16340.20V 4200 Engine Familiarization 12340.10V Dual Stage Air Bag System 14340.10V Versatrak All-Wheel Drive System 10250.12D Emerging Issues Seminar - Dec. 2001 16040.02W OBD II 10250.01D Emerging Issues Service Know-How Seminar - January 10250.13D Technology Close-Up Service Know-How Seminar - January 2001 16046.10W 6.5 L Diesel Engine 12040.10V Wind Noise and Water Leak Concerns 10342.03V 2001 Pontiac New Model Features 16340.10V Duramax 6600 Diesel Engine 17340.20V ZF 6 Speed Manual Transmission: Introduction & Exchange 17040.01V Hydra-Matic 4L60-E Transmission DTC P1870 Diagnosis 10340.01V 2001 Chevrolet/GMC Truck New Model Features 18044.16D2 Body Control Systems - Part 2 18044.16D1 Body Control Systems - Part 1 13041.10W Steering Service 11044.00D1 Introduction to Air Conditioning - Part 1 17041.20W Automatic Transmission Diagnostics 16048.15W Tech 2 Familiarization 15045.20W Bosch Series 5 ABS/TCS 16040.02W OBD II 22048.22W GM Air Bag Systems 22048.22H GM Air Bag Systems 22249.50W Waterleak & Windnoise Repair 22249.50H Waterleak & Windnoise Repair 15045.40W Delphi Chassis Series VI and DBC 7 ABS/TCS 16045.20H Diesel Engine Performance 13042.10D1 Vibration Correction - Part 1 13042.10D2 Vibration Correction - Part 2 13042.10W Vibration Correction 13042.10H Vibration Correction 14041.10D1 Rear Axle & Propeller Shaft - Part 1 14041.10D2 Rear Axle & Propeller Shaft - Part 2 14041.10H Rear Axle & Propeller Shaft 14043.10W AWD & 4WD & Auto 4WD 15045.10D1 Foundation Brakes/ABS System Service - Part 1 15045.10D2 Foundation Brakes/ABS System Service - Part 2 15045.10H Foundation Brakes/ABS System Service 15045.10W Foundation Brakes/ABS System Service 11044.00D2 Introduction to Air Conditioning - Part 2 14041.10W Rear Axle & Propeller Shaft 11044.00W Introduction to Air Conditioning 16043.40W Engine Mechanical Diagnosis/Measurement 19047.03H Entertainment Systems 19047.06W Security Systems 19047.03W1 Entertainment Systems 11044.00W Introduction to Air Conditioning 14041.10W Rear Axle & Propeller Shaft 16048.15W Tech 2 Familiarization 15045.10W Foundation Brakes/ABS System Service 13042.10W Vibration Correction 13241.20V Silverado/Sierra Vibration and Launch Shudder Correction 12241.20V G-Van Sliding Door Repair 19040.10D1 OnStar Diagnosis and Repair Part 1 13043.10H Chassis Electronics 86969 16240.25B Bi Fuel Vehicle (G-Van) 16044.10W2 GM Powertrain Performance - Part 2 16044.10W1 GM Powertrain Performance - Part 1 16044.10W3 GM Powertrain Performance - Part 3 16041.01W Battery, Charging, & Starting 19040.10D2 OnStar Diagnosis and Repair Part 2 19040.10D1 OnStar Diagnosis and Repair Part 1 16044.10D3 GM Powertrain Performance - Part 3 16044.10W3 GM Powertrain Performance - Part 3 16044.10W2 GM Powertrain Performance - Part 2 16043.40H Engine Mechanical Diagnosis/Measurement 16043.40D1 Engine Mechanical Diagnosis/Measurement - Part 1 16043.40D2 Engine Mechanical Diagnosis/Measurement - Part 2 22048.22D2 GM Air Bag Systems - Part 2 22249.50D Waterleak & Windnoise Repair 15045.20D Bosch Series 5 ABS/TCS 22048.22D1 GM Air Bag Systems - Part 1 18043.01W Electrical/Electronics Stage 1 18043.03W Electrical/Electronics Stage 3 18043.02W Electrical/Electronics Stage 2 16044.10W1 GM Powertrain Performance - Part 1 15045.40D Delphi Chassis Series VI and DBC 7 ABS/TCS 14043.10D AWD & 4WD & Auto 4WD 16044.10D1 GM Powertrain Performance - Part 1 16044.10D2 GM Powertrain Performance - Part 2 16044.10H GM Powertrain Performance 16045.20D2 Diesel Engine Performance - Part 2 16045.20W Diesel Engine Performance 16045.20D1 Diesel Engine Performance - Part 1 18043.03W Electrical/Electronics Stage 3 18043.02W Electrical/Electronics Stage 2 13043.10W Chassis Electronics 19047.03D Entertainment Systems 18043.01W Electrical/Electronics Stage 1 C8003.02 ELECTRICAL/ELECTRONICS - STAGE TWO COMPUTER BASED TRAINING C8003.03 ELECTRICAL/ELECTRONICS - STAGE THREE COMPUTER BASED TRAINING C7000.00 UNDERSTANDING AUTOMATIC TRANSMISSIONS C6018.15 TECH 2 FAMILIARIZATION CBT C8003.01 ELECTRICAL/ELECTRONICS - STAGE ONE COMPUTER BASED TRAINING 16013.00 5.7L (LS1) SPECIALIZED ENGINE REPAIR 10344.02BONNEVILLE 2000 NEW MODEL TECHNICAL FEATURES 10344.01 BUICK 2000 NEW MODEL TECHNICAL FEATURES 10342.01 PONTIAC/GMC 2000 NEW MODEL TECHNICAL FEATURES 14001.00 REAR AXLES AND PROPELLER SHAFTS 56009.50 P-CHASSIS POWERTRAIN CONTROLS 55000.01 BASE BRAKE FUNDAMENTALS CPT 10016.00 INTRODUCTION TO ELECTRONIC SERVICE INFORMATION (ESI) AND INTEGRATED SERVICE SOFTWARE (ISS) 16009.20 GEN III V8 POWERTRAIN CONTROLS 16018.05 GM DIAGNOSTIC AND INFORMATION TERMINALS 50399.05 1999 PONTIAC NEW MODEL FEATURES VIDEO 55205.06 DELPHI BRAKE CONTROL 7 (DBC7) ABS CPT 56013.02 GENERATION III V8 CAST IRON BLOCK ENGINE MECHANICAL CPT 56013.02 GENERATION III V8 CAST IRON BLOCK ENGINE MECHANICAL CPT 18003.14 INTERMITTENT ELECTRICAL CONCERNS DIAGNOSIS 58001.00 U-VAN POWER SLIDING DOOR CPT 50399.07 1999 GMC SIERRA NEW MODEL FEATURES VIDEO 58002.01 DENALI & ESCALADE BODY CONTROL MODULE (BCM) CPT 13003.02 BOSCH 5 SERIES ABS/TCS 15005.12 DELPHI CHASSIS VI ABS/TCS 52002.10 J-CAR CONVERTIBLE TOP WATERLEAK REPAIR CPT 58000.00 HIGH INTENSITY DISCHARGE (HID) LIGHTING SYSTEM 16030.02 ON BOARD DIAGNOSTICS GENERATION II 10299.99 SPECIAL ELECTIVE TRAINING: GENERAL AUTOMOTIVE 50399.00 1999 PONTIAC GRAND AM (GMX130) NEW MODEL FEATURES VIDEO 56015.15 OBD II HISTORY & 1996 FEATURES 14003.05 AUTOMATIC FOUR WHEEL DRIVE 56012.01 F-CAR 5.7L (LS1) POWERTRAIN CONTROLS CPT 59407.06 GM SECURITY SYSTEMS CPT 56013.01 5.7L (LS1) GEN III ALUMINUM ENGINE MECHANICAL CPT 56015.15 OBD II HISTORY & 1996 FEATURES 56030.02 1998 OBD II AND FUEL INJECTION 18002.01 TRUCK BODY CONTROL MODULE (TBCM) 59000.00 ONSTAR 13299.99 SPECIAL ELECTIVE TRAINING: STEERING & SUSPENSION 22209.50 WATERLEAK AND WINDNOISE DIAGNOSIS AND REPAIR 16015.25 6.5L DIESEL OBD II 57017.00 4T40E SYSTEM DIAGNOSIS & REPAIR 18001.11 ELECTRONICS STRATEGY BASED DIAGNOSTICS 59407.02 CHEVROLET SECURITY SYSTEMS 11005.25 HVAC SYSTEM DIAGNOSTICS 22002.64 F-BODY T-TOPS/CONVERTIBLE 59407.04 PERSONALIZED AUTOMOTIVE SECURITY SYSTEM III 22008.22 GM AIR BAG SYSTEMS 16015.20 6.5L DIESEL EFI/MECHANICAL 50397.23 GMC TRUCK NEW MODEL FEATURES PULSAT TELECAST 50397.22 1997 U-VAN NEW MODEL FEATURES TELECAST 16009.10 GM FUEL INJECTION DIAGNOSIS 15004.50 INTRODUCTION TO ANTILOCK BRAKES (ABS) 16018.15 TECH 2 FAMILIARIZATION 57015.00 4T40-E TRANSAXLE 19007.03 GM AUDIO SYSTEMS 11004.00 INTRODUCTION TO A/C 18001.02 SPECIALIZED ELECTRONICS TRAINING 52209.55 WINDSHIELD INSTALLATION CPT 50396.23 GMC TRUCK NEW MODEL FEATURES PULSAT TELECAST 57490.00 HYDRA-MATIC 4T60E ELECTRONICALLY SHIFTED TRANSAXLE DIAGNOSIS 52400.00 AURORA FRAMELESS GLASS 56091.12 ZR1 LT5 ENGINE MECHNICAL 56014.05 4.1 /4.5 /4.9 LITER ENGINE MECHANICAL 14003.04 ALL WHEEL DRIVE/FOUR WHEEL DRIVE SYSTEMS 50396.23 GMC TRUCK NEW MODEL FEATURES PULSAT TELECAST 59407.03 PASSLOCK THEFT DETERANT CPT 56002.00 CENTRAL SFI FOR TRUCKS 53092.00 ADJUSTABLE STEERING COLUMN SERVICE & DIAGNOSIS 56015.15 OBD II HISTORY & 1996 FEATURES 56500.01 3100 SFI - BUICK ONLY 16018.10 TECH 1 FAMILIARIZATION 56091.01 4.3 LITER ENGINE MECHANICAL (CPI) 56015.10 ON-BOARD DIAGNOSTICS GEN II HISTORY & 1995 FEATURES 57490.00 HYDRA-MATIC 4T60E ELECTRONICALLY SHIFTED TRANSAXLE DIAGNOSIS 55205.04 TEVES MARK IV ANTILOCK BRAKE SYSTEM 59407.01 PASSKEY 2 SELF DIAGNOSTICS 55205.04 TEVES MARK IV ANTILOCK BRAKE SYSTEM 51010.15 134A RETROFIT FOR GM CARS AND TRUCKS 57490.00 HYDRA-MATIC 4T60E ELECTRONICALLY SHIFTED TRANSAXLE DIAGNOSIS 56010.00 SERVICE PROGRAMMING SYSTEM 51010.00 R-134A AIR CONDITIONING REFRIGERANT 55205.05 DELCO MORAINE ABS VI Automotive Network, Inc., Copyright ©2012
