98 Sierra Brakes: Warped Rotor, or???
V-8Fan
06-30-2003, 04:33 AM
I have a '98 GMC Sierra 1500. I really like this truck...the way it runs (!!!), the way it looks, no complaints! BUT, when I am braking, I feel pulsation in the brake pedal. Some have said the ABS does that, but I am wondering if I have a warped rotor. I bought the truck with 39,000 on it, and I don't recall it ever not doing this. Yeah, yeah, I know---I shoulda noticed when I test drove it, but that's water under the proverbial bridge.
Thanks in advance!
Flatrater
06-30-2003, 11:03 PM
GM has had alot of problems with brake rotors warping and rusting. With your kind of mileage it would be a safe bet that the rotors need to be cut! ABS you would feel it in the brake pedal and it would be a real fast pumping action.
V-8Fan
07-01-2003, 04:21 AM
Mmmm...I think I understand, Flatrater. I have felt the anti-lock operate before, and I think you're telling me that if it was the ABS doing it, it would be pulsating at the same rate as when the thing goes into anti-skid mode. Come to think of it, it makes sense that the anti-lock does its thing at the same rate ANY time it is active. Am I on the right track?
I'll pull those rotors and take them to town to be turned.
Thanks!
chuxted
03-21-2004, 12:22 AM
Being in the autoparts bussiness, turning rotors can be a cheap fix, but consider this. When a rotor is turned, you are effectivley taking away friction material from the rotor making it thinner and thinner and not neccessarily preventing future warpage. Turning rotors can cost up to $20.00 each where a new rotor cost will cost starting approx. $35.00. How much is your life worth to you?
Think about it.
herefordman
03-22-2004, 09:17 PM
Where do you find $35. front rotors for a GMC truck ?? Even offshore ones cost more than that.
And the easy test for the anti-locks ?, is just unplug the anti-lock motor and if the pulsing goes away, then it ain't the rotors.Good luck.
herefordman
03-22-2004, 09:20 PM
Sorry guys I just realized how old that thread is, ignore at will.
