Here's what I have,How should I do it ?
bizuca
06-28-2003, 07:56 PM
I'll try to do my girlfriends Jeep Grand Cherokee for the second time,everything will be done by hand,I'm really concern about the outside.
Here's what I have :
Maguire's Car Shampoo ( Gold Class )
Maguire's Wax ( Gold Class Liquid )
Maguire's Hot Shine High Gloss Tire Spray
Maguire's Hot Rims /Cool Care All Wheel Cleaner
Rain X
Mothers California Gold Clay Bar System
The 1st time I only washed,no wax or clay,was too hot.Next time I want to be done right.Remember all this will be done by hand.
Am I missing something ?What would be the right procedure for the products I have.
Can you guys guide my on the step by step on this.
Thanks a lot
bizuca
06-28-2003, 09:58 PM
What it gets me is Polishing & Glazing
When do I polish and/or glaze and wax ???
1- Washing
2- Drying
3- Claying
4- Washing again
5- Waxing ????
5- Polishing ????
6 - Glazing ????
Totally lost,sorry guys.:confused:
BullShifter
06-28-2003, 11:24 PM
Never clean/wash/wax in direct sunlight
1. Quick rinse
2. Spray chemicals, scrub, rinse. bugs, wheels, tar, tires wheels wells, etc.
3. Wash main body with car wash shampoo
4. Dry with a chamois, all crack, door & trunk jambs, gas filler door, etc.
5. Clay bar to remove contaminants(clay bar=cleaner)
6. Polish
7. Glaze
8. Wax or sealer(alway protect after you clean)
9. Clean outside windows
10. Apply tire shine & dress trim
Polishes are designed to produce a shine in the paint surface. It does this my removing the top layer of paint, also light oxidation & light scratches/swirls. Polishing by hand can have very little effect. Apply it as you would wax except buffing off before it dries. When working by hand I dont do the circular motion, staight back and forth to reduce any swirling.
Glaze fills imperfections/micro scratches
Compound is highly abrasive to remove heavy oxidation/scratches.
Wax is to protect, may only last 30-60days. Carnauba wax!
Sealant is polymer & last longer than normal wax. 4-6months Car dealer sell this stuff on new car for $500 or more. My cost to apply the same product is $3-5.00 per car/truck.
By far the best reults will come from a multi step process done with a high speed polisher. These give major swirls in the wrong hands. Random orbit buffers will give decent results with 50% less work time than by hand & no swirls!
Order of use:
1. Compound - most aggressive(only used on severe paint damage)
2. Polish - slighly aggressive
3. Glaze- non aggressive, fills in flaws left from polishing
4. Wax - provides protection, not shine
5. Sealant - deepens color while protecting longer than wax.(hard to work with, black is the worst) Use black paint sealant for black cars.
http://www.automotiveforums.com/vbulletin/t112336.html
bizuca
06-29-2003, 11:31 AM
Thanks Jack:bigthumb:
The car's painting looks very good,just a few scratches almost invisible.2 weeks ago I washed,dryed with chamoi then 100% cotton towel,it looked very nice.
I want to know if the painting look almost new,I have to go thru all the steps,like if the car was beat up.
Which polish and glaze would you guys recomend ?
Do I really need to glaze it ???
Thanks again :wink:
BullShifter
06-29-2003, 04:05 PM
If the paint is in good condition I would recommend the following process:
1. Wash/dry (bugs, tar, etc)
2. Clay Bar
3. 1-step cleaner wax (meguiars is decent for over the counter)
or
1. wash/dry
2. clay bar
3. show car or new car glaze by meguiars
4. wax
or
1. wash/dry
2. clay bar
3. polish(swirl remover by meguiars)
4. wax
polishing is almost a waste of time when doing by hand since little results if any will be seen. For paint in good condition you will notice more with the hand rubbed glaze(wet look/depth in color). If you want the process to be quick - try using Paint Perfection Glaze, I use more of this thany any other product.Paint Perfection Glaze (http://topoftheline.com/hitoncleanse.html)
Most the products i use are made by Hi-Temp but for over the counter stick with Mothers & Meguiars -- Turtle Wax stuff sucks
Detailing products // Q/A Tips & Tricks (http://www.topoftheline.com)
To make apply/removing wax/polish/glaze invest into a cheap Craftsman orbital buffer, it will cut work time in 1/2, leave no swirls, & better results than by hand.
The best glaze (http://www.zymol.com/vintage2.htm)
Hi-Temp (http://www.hitempinc.com/) - They list all directions for method of use
