Rockford Fosgate Wiring Diagram
mdavid02
06-27-2003, 12:14 PM
Does anyone know the wiring diagram for the Rockford Fosgate 6 disc indash changer. I am adding a amp and need to know the left and right speaker positive and negative outputs and the remote turn-on wire.
Thankyou,
berz26
08-19-2003, 12:03 AM
Does the deck have pre amp out or are you going to use a line converter. If so you will have to use a low level converter because the power comming out of the desk will be high-powered. Also if you take the deck out you can run a hot wire to one side of the speaker and ground the other. look how the speaker pops you want it to pop up. If it does then the power wire touching the speaker wire is a pos wire if not switch....
