Dohc 3.4Blue02R6 06-22-2003, 04:56 AM Where can I find one in relatively new condition, or better yet new? None of the local junkyards have any. Help me because my 2.8 is going to explode!!:banghead: Blue02R6 06-25-2003, 05:32 PM Help! Help! Help! My engine will not last long. netjunkkie 08-13-2003, 06:30 AM blue u have any specs on hp and torque for the 3.4 dohc turbo? Blue02R6 08-17-2003, 08:47 PM I don't know any for a turbo 3.4 but I found these for the N/A at http://www.60degreev6.com Engine Description (LQ1) 3.4L DOHC 60 degree V6 Horsepower (HP@RPM) 210@5200 Torque (ft-lbs@RPM) 215@4000 Block Cast Iron Heads Aluminum Valves 24 Displacement 3.4L (3350cc, 207ci) Bore 92mm (3.622") Stroke 84mm (3.3122") Compression Ratio (91-95) 9.25:1 auto 9.5:1 Manual (96-97) 9.7:1 Cam Specs (From GM) 248 degree adv. duration 163 degree @ .050" .370" lift (Measured off a set of 94 cams) Int: 205 Degree Duration @ .050", Lift = .369" Exh: 213 Degree Duration @ .050", Lift = .373" Detailed Information Cylinder Bore Diameter: 92.010 mm - 92.028 mm Out-of-round - MAX: 0.007 mm Center Distance: 111.76 mm Deck Height: -.004" Piston Diameter: 91.970 mm - 92.028mm Clearance: .022mm - .058mm Piston Ring - Compression - Groove Clearance 1st: .04-.09 mm 2nd: .04-.09 mm Gap (at gage dia.) 1st: .30mm - .56mm 2nd: .48mm - .74mm Oil Groove Clearance: .202mm-.048mm Gap (Segment at gage dia).: .25mm - .76mm Tension 1st: 5.6 lbs 2nd: 4.8 lbs Oil: 12 lbs. Piston Pin Diameter: 22.9915mm - 22.9964mm Clearnace: 0.0116mm - 0.0235mm Fit in Rod - Press: .0165mm-.0464mm Crankshaft Main Journal Diameter - All: 67.241mm - 67,257mm Taper - Max: .005mm Out-of-round - Max: .005mm Main Bearing Clearance: .032mm - .077mm Main Thrust Bearing Clearance: .032mm - .077mm Crankshaft End Play: .06mm - .21mm Crankpin Diameter: 50.768mm - 50.784mm Taper - Max: .005mm Out-of-round - Max: .005mm Rod Bearing Clearance: .028mm - .082mm Rod Side Clearance: .36mm - .64mm Camshaft Lobe Lift - Intake: .370" @ 112 degree Crank ATDC - Exhaust: .370: @ 111 degree Crank BTDC Journal Diameter: 54.9875mm - 55.0125 mm Bearing Inside Diameter: 47.516mm - 47.541mm Journal Clearance: .037mm - .088mm Valve System Lifter: Hydraulic Face Angle: 45 degrees Seat angle: 46 degrees Seat Runout - Max: .05mm Seat Width - Intake: 1.25mm - 1.50mm - Exhaust: 1.60 mm - 1.90 mm Stem Clearance - Intake: .028mm - .066mm - Exhaust: .035mm - .078mm Valve Spring Free Length: 42.04mm Load - Open: 180# @ 1.03" Load - Installed (all): 75# @ 1.400" Approx. # of coils: 4 netjunkkie 08-18-2003, 06:52 PM lol i was just looking for hp and torque but that helps too :) thanks blue Blue02R6 08-19-2003, 07:26 AM Your welcome. I like the mirrors on your Fiero. netjunkkie 08-19-2003, 08:25 PM as far as i know they are stock 85 gt mirrors badassgremlin 08-21-2003, 01:01 PM check ebay if u want u should check places that sell remanufactured engines :rofl: Blue02R6 08-21-2003, 03:38 PM I finally found a local place that will sell me a used 3.4 for $1400 or a reman. for $2200. They will do the convesion for $4000+ other parts. Thats more than I paid for my Fiero! netjunkie your mirrors are painted the body color. Right? They were painted black from the factory, as far as I know. netjunkkie 08-31-2003, 11:04 PM ya i had them and the mirror control painted same as car Blue02R6 09-26-2003, 03:04 PM I found a Z34 lumina for $200 but it's in atlanta. They want $800 to ship it back here. Blue02R6 09-26-2003, 03:11 PM I just thought I'd ask, anyone know what it would take to turbo a 3.4? I'd need a turbo, some custom exhuast and intake work, but what else? And how would i figure out the best turbo to use? LoW_KeY 09-27-2003, 01:10 PM not sure.. haven't really looked around at DOHC in the fiero I was all set on the L67.. try http://www.dohcfiero.com ?? Kameo Kid 10-15-2003, 10:51 PM Are you still looking for NEW 3.4 DOHC ?? I may know where one is.. Blue02R6 10-18-2003, 05:22 AM Yes, but right now my money is very tight. Automotive Network, Inc., Copyright ©2012
