Car wouldn't startheathershonda 06-21-2003, 04:59 PM I was just comming out of the store...got into my car and it woudn't start. I tried three times, on the third try it kickd over. I just had a new coil pack put in it a few months ago b/c I was driving along when it just cut out on me. Do anyone have any ideas what this might be so I won't get stuck next time ? BullShifter 06-21-2003, 05:22 PM Do anyone have any ideas what this might be so I won't get stuck next time ? :icon16: did it only happen 1 time? 002star 06-21-2003, 06:08 PM Main relay!!!!! I have had the same thing main relay all the way! BullShifter 06-21-2003, 11:14 PM Just because a honda doesnt start, does not mean its always the main relay. It could be many things. spark plugs spark plug wires coil igniter cap rotor fuel filter fuel pump bad gas starter battery alternator ignition switch and so on . . . . 002star 06-22-2003, 01:47 PM :comprage1 But the way she describes it was it. That is what everybody else is having problems with his time of year. I had the same problem last year. The interior of the car get warm, solder joints on the relay difuse and the the car doesn't start for a couple crank. The same thing happened to my car. It is really quite common with 90-93 Accords sane thing happened to my aunt last year nd she has a 92. So that would be the first thing I change b16a3sol 06-22-2003, 06:09 PM im going with the main relay also. costs about $20 at the dealership if i remember from when i had to buy one a couple years ago. you can always check to see if your ignitor is in spec and the cap and rotor are not worn down. also check to make sure the plugs are not fouled. 002star 06-23-2003, 07:04 PM Really it is more like $75 when it bought it both times Both Last year heathershonda 06-24-2003, 11:44 AM Jackasssi....it happened one time last year. Jut left the car alone for about 20-30 minutes, went back out and it started right up. But this time it seemed different. BullShifter 06-25-2003, 12:35 AM Im guessing that its the igniter. Replacing the main relay wouldnt be a bad idea if you dont know if its ever been replaced. Simple & cheap, may save your ass some day. First I would check tuen-up items:spark plugs, wire, cap/rotor, etc. When you were trying to start it was it cranking over, or nothing at all? heathershonda 06-25-2003, 01:17 AM It was cranking...finally turned over on the third try. BullShifter 06-25-2003, 02:00 AM If it happens again, turn the ignition with out starting and listen for the fuel pump. It should turn on for a few seconds then shut off. If you dont hear it the most likely your main relay is shit! I still think igniter:wink: or the tune-up parts 002star 06-26-2003, 02:40 PM You could also go out an buy a book that i use hat is really helpful for honda and working on them it is called Chilton. That helped me the other night fix my aunt car.........again. You could buy that it helped me BullShifter 06-26-2003, 05:26 PM If your gonna purchase a repair manual make sure its a Helms heathershonda 06-26-2003, 09:56 PM I have a Hanes book...will that work?? I've been reading up on that about minor tune ups I can do myself. BullShifter 06-27-2003, 01:27 AM That will work. Maybe your muffler fluid is low :eek: 002star 06-27-2003, 11:09 AM I don't know i think i would check the blinker fluid :wink: :tongue: heathershonda 06-29-2003, 07:19 PM Yeah, I'll make sure those two will get checked also. :lol: :lol: BullShifter 06-29-2003, 09:37 PM Originally posted by heathershonda Yeah, I'll make sure those two will get checked also. :lol: :lol: :iceslolan Automotive Network, Inc., Copyright ©2012
