nos and turbo
speedy6301
06-16-2003, 09:34 PM
what are some good nos and turbos and what stage for the reg. lancer basic model
thanks and what do i need to change in my engine??
marky5505
10-31-2003, 08:33 AM
I have also been looking for turbos for my 03 OZ. I did research and the T-28 turbos seem the easiest to mount without mods to the engine. You can find it at www.roadracemotorsports.com. It seems expensive here I have also found turbo kits at www.turbodiscounters.com for a less, but as far as quality go Im not sure about either of these? I am still doing my research.
speedy6301
10-31-2003, 06:01 PM
k thanks plez keep posting
marky5505
11-01-2003, 09:28 AM
Alright heres some stuff I found out, there is 3 stage turbos available for the lancer standard model. Stage 1 has no intercooler and can only sustain 5 psi. The stage 2 has an intercooler and can sustain 7 to 10 psi without modification to internals of the engine. The stage 3 requires many mods to the internals and can push anywhere up to 15 psi (standard). You may be able to get more psi out of it. Stage 3 could give you 150+ ponies more. The stage 1 increases your hp by around 50%. When you add the stage 2 components to the stage 1 kit, it increases the stage 1 power by 33 additional %. So in theory if you have the 120 hp model stage one gives you 180 hp, when you add the stage 2 it gives you 240, and if you go all out and do the stage 3 then you will be pushing 270 hp. This is the information that I found on the net so I hope it is accurate. Also remember that the turbo remains the same on all kits, so you could do a stage 1, add stage 2 later, and then when you get more money add the rest to make the stage 3 kit. Anyway I hope that this helps!!
marky5505
11-01-2003, 03:07 PM
Hey just got some more info, emailed and got more information and prices thought that I would post it for you if your interested. This is an email I recieved today. Just posted it for ya:
The stage 2 turbo system is $3450, it includes everything that you need and
contents of the kit can be found online, you can safely run 10psi on our
stage 2 turbo setup which is good for 100hp with intercooler.
Thanks
Matt
HobieKopek
11-03-2003, 10:54 AM
Try looking through older posts. I've posted about 40 times on turbo kits for the Lancer alone and I don't feel like writing it all over again. However, let me reiterate that nitrous on a Lancer's stock pistons is a very bad idea.
