problem with my 88 cherokee
tjganger
06-12-2003, 03:29 PM
i have an 88 cherokee i was driving it with a bad clutch the day i was going to replace the clutch it was acting up not going over 2000 rpms when warm then it would get more r's if i let it cool for a few minutes anyhow i replaced the clutch thinking i could troubleshoot it later then i got the clutch in and it wont start at all no pluse to the injectors and no spark to the plugs please help i love my cherokee (has the france 5 speed transmission in it with the in line 6 ):confused: :confused: :confused: :confused: :confused:
94XJSport
06-19-2003, 05:55 PM
Check you CKP a.k.a. your crank position sensor, or TDC sensor. This is the only sensor that will keep you from getting any pulse to your coil.
You had to have disconnected it to remove your tranny, so you may have not reconnected it.
Good luck!
tjganger
06-20-2003, 08:58 AM
i even tried raplacing it so i know it is plugged in
JScot
10-25-2003, 02:54 PM
I have an 88 with the same problem. I Cleaned the IAC last Monday and it ran. I then changed the plugs and it hasn't started since. There's no power to the coil. I checked the Crank Shaft Position sensor like it says to do in Haynes and I recieve continuity between A and B. Haynes says there should be no continuity so I got a new CKP. I checked the continuity of the new CKP and it too has continuity between A and B so I haven't installed it. If you got yours running, can you let me know what it needed?
