springs vs coilcoverscivicrac3rboi 06-11-2003, 01:57 PM wassup. i have a question and i'm hoping you guys could help make a decision. i'm not really sure whether to go with springs or coilovers for my car. what seems to be better? well for one, i dont want my ride to be bouncy or too stiff. what do u guys suggest. thanx for ur help:smile: :bigthumb: SilverY2KCivic 06-11-2003, 02:29 PM If you want the smoothest ride, then true FULL coilovers is the way to go. Well worth the high cost as well. Otherwise I'd recommend for sleeve type coilovers ground controls with Koni yellow shocks, and for just a lowering spring setup, you can't go wrong with Eibach Pro Kit springs, over some Koni yellow shocks. HookdUpTeg99 06-11-2003, 02:55 PM Personally, I hate Eibach Pro Kit springs...I had them on my integra for about a week before I couldn't stand them anymore. They don't lower your car equally...the front sits higher than the rear which is annoying as hell :eek: I ended up buying the Ground Control coil overs and KYB adjustables....the ride was great considering i only spent 600 total. :biggrin: Ace$nyper 06-11-2003, 02:57 PM well i'm using Skunk2 coils with Koni yellows well to be honest at the time i'm writing this the skunks are being put on lol but i've heard many great things about this combo. i'll post later tonight after i take her for a spin. Ace$nyper 06-11-2003, 08:52 PM OK i'm back from zipping along with the Skunks2 in and I love it it's like its on rails needs aliment so i haven't taken any of my normal speedy turns but it's ride quailty is just the same as before i'm really happy about them. SilverY2KCivic 06-11-2003, 09:06 PM Originally posted by HookdUpTeg99 Personally, I hate Eibach Pro Kit springs...I had them on my integra for about a week before I couldn't stand them anymore. They don't lower your car equally...the front sits higher than the rear which is annoying as hell :eek: I ended up buying the Ground Control coil overs and KYB adjustables....the ride was great considering i only spent 600 total. :biggrin: No offense, but are you sure they didin't get put on backwards, like they put the fronts on the rear, and the rears on the fronts? Because NO lowering spring kit that I've heard of does that. Or perhaps maybe your rear struts were blown and therefore sagged the rear down a bit making it seem the front was higher than the rear? I can't believe the springs are made to sit higher in front than in the rear. loesch8102 06-12-2003, 12:34 AM I think he's right. I've heard of this before. Only on Integras though. That's why I chose H&R instead. It's all hearsay though. I heard it from a friend. BullShifter 06-12-2003, 01:38 AM Coil-overs may be overkill for the street but the provide the best formula for controlling ride height & stiffness. Coil-overs are good for street use 1"-2" drop & 2"-4" for autocross. Going lower than 2" messes with the suspension geometry. Dont buy just "Lowering Springs", make sure they are a performance type spring. If you dont want bouncy/stiff stay above a 2" drop, going to low takes away suspension travel. Bottoming out is not fun, bouncing on the bump stops sucks. Lower is not always better. Dont buy price, buy QUALITY. felixc 06-12-2003, 03:31 AM Originally posted by jackasssi Dont buy price, buy QUALITY. cant stress this enough. here is a picture of what happened to my $150 maxspeed "coilovers". :swear: replaced them with tokico illumina r full coilovers and the ride quality drastically improved :bigthumb: felixc 06-12-2003, 03:49 AM here's the pic civicrac3rboi 06-12-2003, 04:22 AM thanx for ur help. but i have one more question. say if i go with 18's on my civic how much would i drop it for not to rub?? or will it rub already without dropping it??? ps. dang homie, what happen w/ ur coil-overs??:confused: neunan 06-12-2003, 05:26 PM 18s on a civic? i guess its preference, but 17s look pretty damn nice and they'll still perform. 18s are kinda overkill i think. and i dont have an answer for the rubbing question BullShifter 06-13-2003, 12:35 AM That picture shows a perfect reason for staying away from coilover sleeves. Invest in the real thing . . .if you cant afford them, wait til you can or get some good springs & shocks SilverY2KCivic 06-13-2003, 03:01 AM Originally posted by jackasssi That picture shows a perfect reason for staying away from coilover sleeves. Invest in the real thing . . .if you cant afford them, wait til you can or get some good springs & shocks w0rd to that! :cool: civicrac3rboi 06-13-2003, 06:14 AM sup! thanks for all the feedbacks bout my question. so do u guys think i'll b over doing it if i put 18's on my car. how many pppl think i'll b over doin it? should i go with 17's and drop it. if so wut is a good look. 2 inch. or less?? not too slamed and not too high. dont really wanna see a gap. just the tire almost touching the top top of the fender look. i wanna c some pictures. if u guys have some. i've seen some pretty tight rides. well any way, i wanna know wut ppl think bout 18's on civic :bigthumb: neunan 06-16-2003, 08:52 PM i guess its being redundant since i said it before, but yea i think 18s are overkill. 17s are nice... i'd go 18s on a skyline or something bigger like that. im going to go with 17s on my car, and i was even considering 16s for performance reasons. as for the drop, if you get springs with a 1.5" to 2" drop and then some somewhat adjustable shocks or coilovers you can mess with it all you want (i think koni yellows give you almost 4" leeway). but i'd say dont get springs alonethat drop much more than 2" sp3cial_bl3nd 06-17-2003, 11:38 AM First thing i want to clear up is that, you will have the same amount of gap whether you get 18s or 17s. the circumfrence of your tire doesn't get bigger because you get bigger rims, it just reduces the proportion of your wheel that is tire. That's where all the pinner wheels come from. 18's are a bad idea, in my experiences, because you end up having to replace tires a lot, because there is less cushion than on 17s. So bottom line i think 17s are the way to go. Automotive Network, Inc., Copyright ©2012
