boost gaugeEthan_R33 11-11-2001, 02:55 AM hi guys, Im getting the turbosmart 2 stage boost controller and a boost gauge aswell. Does anyone know how to actually hook up the boost gauge??? Im not really sure and dunno if it will have instructions or not. Same with the boost controller. So could someone please tell me how to connect up a boost gauge and the boost controller in "lamens" terms. (im not too mechanically minded) Andrew denjam69 11-11-2001, 03:59 AM just get a pro to do it for u!! u wil fuk it up if u do it yourself Porsche 11-11-2001, 04:08 AM Even though, it's off topic, I just can' get over the fact that my freind calls the boost gauge a "Turbometer". LOL OzzieR33 11-11-2001, 04:42 AM the turbosmart controllers have instructions with them. As do most gauges. U just need to know whats what in your engine bay to set them up properly after following the instructions. YCEE 11-11-2001, 02:24 PM If your boost gauge is a mechanical one, you'll just have to hook it to a vacuum line coming out from the intake manifold. If it is an electronic boost gauge, you'll have a pressure sensor or something that sends a signal back to the boost gauge. For the boost controller, better let a mechanic do it, as different boost controller has different setup. Ethan_R33 11-11-2001, 04:19 PM Ok thanks guys. Im sure its a mechanical one (its a speco one). But i have a HKS intercooler, so im not really sure which is the vacuum line? Can anyone help me out here??? I can post a pic of the engine bay if it helps. Doctor 11-11-2001, 10:40 PM There is a brass bolt about 3cm wide that is not screwed all the way located at the back of the plenum chamber near the idle control screw. Your boost guage will have a bolt the same size as the brass bolt. It is simply a matter of replacing one with the other and then feeding the pressure/vacuum line into the cabin. Sorry I don't pick, I'm not that technically advanse. Regards, Doc SlowGts-t 11-12-2001, 03:02 PM Or you could just tee off the hose to the factory boost (MAP) sensor at mounted on the drivers side of the firewall Automotive Network, Inc., Copyright ©2012
