Any Issues with SR20DET (Black) into 89-90
Frostbyte
06-09-2003, 09:07 AM
I am going to be picking up a 89 240sx fastback for a $1000 hopefully. I just wanted to know ahead of time if there is any issues with swapping the sr20det black top into this year? or is it a pretty clean swap? Also S13 front clip fit ok on this year? The car has some front end damage and I figured on doing the s13 front clip as well. Thank you.
turbo2nr
06-09-2003, 09:29 AM
one problem right off the bat is that the 89 240 sx motor is a sohc and the sr20det is a dohc so the cpu system is different you will have to use the sr20det wireing system.. other than that it seem like a normal engine swap..
btw you can read the f.a.q. and get more info on the swap
good luck on it!
keep us posted
1
180driftking
06-09-2003, 09:30 AM
another honda bandwagon man, well good choice on the 240 tho, i'd say that you get a sr20det from an s14, I've heard that they drop straight in with no problem plus i love the way an s14 turbine sounds.
Frostbyte
06-09-2003, 09:31 AM
good luck on it!
keep us posted
1
I noticed the F.A.Q after I already posted this thanks for your help. I am going to read the F.A.Q right now.
turbo2nr
06-09-2003, 10:21 AM
no probs..
:wink:
Suislide
06-09-2003, 12:22 PM
i don't see why a black top S13 SR20DET WOULDN'T fit into an S13...but it's a good idea to check up anyways.
as sr20 said, there's a couple of wires and sensors and junk you have to replace here and there to make the engine compatible, but other then that, it drops STRAIGHT in.
