Check out this cool Toyota Tacoma
Speedfreak17
11-10-2001, 05:51 AM
I Want one !!!!!
2000 Rod Millen Motorsport
All-Wheel Drive Pennzoil Toyota
Tacoma Truck Specifications
GENERAL
Body Type: Pennzoil Toyota Tacoma
Graphic Design: Mark Jones
Paint: Lanzini Body Works
Drive System: All-Wheel Drive
ENGINE
Engine Preparation: Toyota Racing Development, U.S.A
Type: 4 Cylinder, Twin Cam, 4 Valves per Cylinder, Fuel Injected, Turbocharged
Displacement: 2.1 Liters
Lubricant: Pennzoil
Fuel: TRD Blend
DRIVETRAIN
Transmission: Traction Products 5-speed Non-Synchronized 4-Wheel Drive Gearbox
DIMENSIONS
Curb Weight: 1950lbs
Overall Length: 182"
Overall Width : 76"
Overall Height: 46"
CHASSIS
Type: Chrome-Moly Steel Tube Frame Chasis
BODY
Materials: Carbon Fiber Body, Front and Rear Underwing (Ground Effect Tunnels)
Carbon Fiber: The Advanced Composites Group
SUSPENSION
Shock Absorbers: Ohlins
Front: Double A-Arm with Pushrod and Rocker, Coil Over Suspension
Rear: Double A-Arm with Pushrod and Rocker, Coil Over Suspension
STEERING
Type: Power Assisted Rack and Pinion
BRAKES
Discs and Pads: Carbon Industrie Carbon/Carbon
Disc Size, Front: 14"
Disc Size, Rear: 14"
Caliper, Front: Brembo 8 Piston
Caliper, Rear: Brembo 8 Piston
WHEELS AND TIRES
Wheels, Type/Size: BBS Wheels Front: 17"x12.5" Rear: 17"x12.5"
Tires: BF Goodrich Experimental Comp T/A P335/30ZR17
Power output 900 bhp !!!
http://www.rodmillen.com
Mclaren F1
11-11-2001, 02:18 AM
hahaha Pike's Peak Hill Climb!!!!!! that was the only car to beat the escudo in the hill climb race
NSX
12-13-2001, 09:44 AM
i thought tacomas has a v6 or 8 engine
flylwsi
01-02-2002, 07:43 PM
right... does that really look like a tacoma to you?
that is basically his hillclimb celica with new body work, loosely described as a tacoma...
and tacomas come with an i4 or v6... lotsa those things with a 4 cyl in em... and how many tacomas weigh 1900 lbs... ???
