Weird sound when depressing the throttleskifaster 06-04-2003, 10:41 PM Re: 1995 Porsche 911 (993) Cab: When I depress the throttle there is a distinct and weird noise, a combination of whistle, hiss and whine. If the gas pedal is moved slightly up and down the noise follows the pedal depression, squeaking back and forth. Any ideas about the cause? S2000 06-10-2003, 12:13 AM Its you blow off valves, is ok is normal buymeabmwm3 07-10-2003, 08:58 AM I didn't think the '95 911 was a turbo :eek7: Maybe I'm wrong. If its not, then it can't be blow off valves. Might want to check your intake box and piping. There may be a leak thats causing some whistle on acceleration. Does the noise increase with engine speed (i.e. rpm), or with car speed? Is it present in all gears at the same engine speed? Automotive Network, Inc., Copyright ©2012
