Thunder programmable chips for 4G63Tkikoman59 05-28-2003, 09:54 AM Programmable Thunder chips available for: 4G63T . ECU ID 8618, 8618B 4G92 ECU ID 4828 4G63T evo 1,2,3 ECU ID 7701 Programs available: RPT and Ralliart, mapping for street or race. Very strong torque & top end. Torque band 4500 - 7200 rpm redline 7800 rpm. Runs perfect at 19 psi ( 1.3 Bar )boost pressure with no fuel cut. Adjusted rev limit and omit speed cut (JDM Model) optimized fuel & timing maps. Totally plug & Play, no tuning required. Converts your stock ECU to a programmabla ECU in 20 minutes. $200 shipped anywhere around the world. Will include DIY installation instructions. :smoka: Akidosigh1 11-29-2003, 10:51 AM does this chip adjust the boost on 4g63t cars by itsself? kikoman59 11-30-2003, 09:00 PM no the chip will not increase your boost automatically, but it will allow your engine to accept a high level of boost of up to 19-21 psi, without achieving fuel cut. Rev limit is also adjusted. You will have to get a manual boost controller to adjust your boost manually. Akidosigh1 11-30-2003, 11:35 PM That can't be right. The stock injectors can not handle too much more than 16psi safely. Even then a rewired and larger fuel pump might be needed. I was just wondering cause there are some people with "chips" that claim they raise the boost levels just by plugging it in. You are on here trying to sell chips and you only have 2 posts, both of them being on the same thread. For $200, there are a lot of other things DSMers could spend their money on that would give them a lot more horsepower reliably than a chip. I'm not saying that your chip doesn't work. But there are only 2 people that I know about that's chips are original and work as claimed. TMO and Keydiver chips. And to my knowledge, neither of them claim to make horsepower on their own. Most chips out there are just copies of the TMO chips anyway. Keydiver has come up with his own codes that work and have been proven. I know his(Keydiver) works because I have one and it was free, like it always has been for Galant VR-4 owners. My EPROM chip in my car comes with a 5000rpm stutter box, fuel cut is eliminated, my rev limited has been raised to 7800, I have an AC cut out at 90% throttle and my factory led boost guage now shows knock sensor readings. Can your chip do any of that and do you have the ability to adjust the values when more upgrades are done? or are all your chips the same cause one day i might want to raise my rev limiter to 8500 and it will be done for free... enough bashing though. hope you do well. kikoman59 12-01-2003, 10:43 PM So I see your pretty much set up, so why bother iiquiring bout the chips? But just for your peace of mind, the chips I carry are from Ralliart. The very same chips used in evo 3-4-5-6-7-8 at WRC. When your ready to pump up your 63T with 310 duration cams, big turbo, etc etc, capable of reving 9000 rpm @ 30 psi of boost then give me a buzz & I can set you up. If you just plan on a daily driver, your set up is good enough, stay stock. Automotive Network, Inc., Copyright ©2012
