heat shield dividerdenjam69 11-07-2001, 09:06 PM :alien2: whats the best material to use for a heat shield between the engine and air filter to stop the hot engine bay air getting taken in by the air filter?? Doctor 11-07-2001, 09:20 PM Aluminium (not foil :p) is pretty good. I suppose any reflective/shiny metal would be sufficient enough. Doc denjam69 11-07-2001, 09:23 PM stainless steel ok? TINDUCK RACING 11-08-2001, 07:18 PM stainless steel ok? .......Good reflective material, but too heavy, and holds the heat too much......ally is better, so is foil coated foam plastic..... (just my 2 cents) (and easier to form) cheers, Jon. B.H. 11-08-2001, 11:07 PM I used 3.5mm aluminium sheet... Its easy to bent and fairly easly to cut. Reflects the heat quite well and also looks nice and shiney when the hood is opened up!:grey: denjam69 11-08-2001, 11:16 PM b.h did u put a rubber ribbing around the top of the aluminum to make it a smooth surface?? AKBOSA 11-09-2001, 02:18 AM For those in Sydney..... you can get this foam material with some shiny backing.... which is a heat shield. I bought this material really cheap.... at CLARK RUBBER outlets . I got a metre of it for $10!! And shared it among three cars!! It works! I used it to cover the whole pod filter area which practically shileded the whole area.... A friend of mine..... (sorry mate, if u are reading), bought a really small peice for $90 at a certain performanc shop in Sydney..... So....... :D lixid 11-09-2001, 03:02 AM can anyone who did it post some pics so i can do it to my car?? than you very much denjam69 11-09-2001, 10:00 PM yes post sum pics please B.H. 11-11-2001, 05:23 PM denjam69 ... Nah i didnt to put rubber ribbing round the top. I bent the edges of the vertical plate at 45 degrees and the same with the plate that fitted on top then put three screws in to hold it. It seemed to seal really well. The shield gets quite warm, especially after a long or fast run, so if you do use some rubber to seal it then make sure you get something that wont burn or melt when the heat gets up.:silly2: denjam69 11-11-2001, 06:44 PM bh so the whole air filter on yours is shielded? not just from the side? B.H. 11-11-2001, 07:22 PM Yeah the whole thing is shielded... Ill try and get some pics of it online in the next few days. At first i attempted to arrange it so it was just a side wall heat shield but found it too difficult to stop all the warm air from getting in... Having a top as well allowed for a totally sealed unit. I then took off the front spoiler and took out the factory induction box (just in front of the wheel arch) I cant think why the manufacturers have gone to so much effort to stop induction noise, it seems to restrict airflow sooo much!!) I used the existing pipe with an extension to attach to the vent in the front spoiler, so ONLY cold air is rammed up into the box containing the pod filter. Makes a noticable difference, but takes longer to warm up from cold in the morning.... denjam69 11-11-2001, 07:26 PM SWEET! POST SOME PICS IF U CAN! I AMUSE U CUT THE AL YOURSELF? B.H. 11-11-2001, 07:33 PM yep cut the aluminium myself with a few basic tools, hacksaw, drill, tin snips and a angle grinder for smooting the edges. The aluminium is so flexible... it is really easly to work with once you have figured out the shape... If your gonna give it a try then i suggest that you cut out a cardboard template and get it exactly to the right shape before attempting to cut the aluminium.. makes life a whole lot easier...:bandit: Forsteen 11-14-2001, 07:05 PM Hello all. First post on this forum. Glad no one took my name. Anyway, has anyone else put a cold airbox on? I did and my pod filter sucked in so much are it created a vacuum because of the lack of air causing a restriction like a limiter. I also constructed a sort of ramp to let more air from the bottom. Ethan_R33 11-14-2001, 07:09 PM hi forsteen, yeah ive put a partition between the filter and engine and a cold air duct running from the front spoiler. You had so much air it created a vaccuum?!?!!? how did that happen?:confused: Ethan_R33 11-14-2001, 07:12 PM ps, i put a pic here (http://64.4.22.250/cgi-bin/linkrd?_lang=EN&lah=57988491fd9ff19c6d136ab157d70410&lat=1005782547&hm___action=http%3a%2f%2fwww%2eautomotiveforums%2e com%2fvbulletin%2fshowthread%2ephp%3fthreadid%3d11 119%26goto%3dnewpost) denjam69 11-14-2001, 07:14 PM THE LINK DONT WORK Ethan_R33 11-14-2001, 07:16 PM shit sorry, go to the max boost on r33 then, its in there. Forsteen 11-14-2001, 09:12 PM The Pod filter sucks in so much air at high boost that the cold air box becomes a vacuum (restricts the air needed). I ended up cutting the box down to a partition. This helps more. AKBOSA 11-14-2001, 10:19 PM Well, mine is made of foam with aluminium foil backing, so its more bendable and I can cut it to size with ease.... and stick'em up with electrical tape!! The whole thing is shielded up like a box and I already use the stock air funnel that channels air from the bonnet area... So far, its quieter but I don't really know if there is any air restriction...though its definitely cooler air the filter is getting. :flash: TINDUCK RACING 11-15-2001, 03:08 PM ........a bit like this? denjam69 11-15-2001, 06:19 PM LOOKS NICE!! IS THERE A HEAT SHIELD FROM THE ENGINE HOT AIR THERE 2? I CANT C IT PROPERLY!! TINDUCK RACING 11-15-2001, 06:50 PM ....yes, it's covered with reflective foil, that's why it doesn't show up well on the photo......the divider seals with the bonnet insulation at the top, so the cold air compartment is almost airtight.... laters Jon. denjam69 11-15-2001, 06:58 PM PREETY SWEET DESIGN, DID U USE THE FACTORY COLD AIR SCOOP AT THE FRONT AND MOD THE RUBBER FOR THE BONNET SEAL? TINDUCK RACING 11-15-2001, 07:14 PM ....erm, well, err...yes? ...and erm....no? ......and why all the SHOUTING???? :) :) :) :) :) :) Laters dude, Jon. denjam69 11-15-2001, 07:25 PM I AINT SHOUTING!!!!!!!!!!:flipa: hehe just used to using caplocks at work TINDUCK RACING 11-15-2001, 07:52 PM hehehe let ya off then laters dude Jon. Automotive Network, Inc., Copyright ©2012
