Keyless Remote 93 DeVillehumberts 05-27-2003, 11:27 AM Can anyone tell me how to program a keyless remote for a 93 Sedan DeVille? Thanks, Steve ckb4430 01-07-2004, 05:12 PM 1. Turn ignition switch to off. 2. Jumper Assembly Line Diagnostic Link Connecter(A.K.A ALDL connecter located behind center instrument panel, below ashtray) terminal G. (PPL/WHT) to terminal A (BLK/WHT). Doors lock and unlock, and trunk release activates in approximately 2 seconds. 3. Press any button on one transmitter. Door locks lock and unlock, and trunk release activates in approximately 2 seconds. The first transmitter is now programmed. 4. Repeat step 3 using the other transmitter. If only one transmitter is being used, go to step 5. 5. Disconnect jumper from ALDL connecter. Check to see that both transmitters operate door locks, repeat steps if necessary. hilliardc 02-18-2004, 08:14 PM does this work for a 99 el-dowg lorenjr 07-09-2007, 11:22 PM I was just given a 93 deville. is there any way to find out if it has keyless entry? i didnt recieve any manuals or anything with it caddydaddy 07-10-2007, 03:04 PM does this work for a 99 el-dowg No, you have to go to the dealer for your car. caddydaddy 07-10-2007, 03:05 PM I was just given a 93 deville. is there any way to find out if it has keyless entry? i didnt recieve any manuals or anything with it You can check the RPO codes. Onblsht 07-22-2007, 08:30 PM I don't believe there were ANY Cadillacs made from 93-present that didn't include factory keyless entry with 2 remotes. Automotive Network, Inc., Copyright ©2012
