Here is the program procedure!
1 close all doors.
2 put ignition key into the cylinder.
3 press and hold the lock switch.
4 while holding tht door lock switch in the unlock position cycle the ignition on,off,on,off.
5 release the door lock switch, the doors will lock and unlock.
6 press and hold the lock and unlock buttons on the remote for at least 15 seconds.
7 repeat for other remotes.
8 remove the ignition key and try the remotes.
Good luck!
