Dash & Tail lights not working
Suwee
05-15-2003, 06:56 PM
Hello! I recently replaced my stereo and now my dash and tail lights do not work when I turn on my headlights. I checked the power source to the dash dimmer switch and there is no power. I have checked every fuse in my car and replaced one that was out. This did not solve my problem.
Does anyone out there have any suggestions on how to fix this? Thanks!;)
bizzzaro
11-12-2003, 08:40 PM
hey I am looking to fix this same problem but it just happend to my truck with no tampering and the fuses all look ok. ttt
sk8rpunk716
02-14-2004, 02:47 AM
You will have to replace the same fuse...I had thys problem. You will need to use somethyng bigger though, I belive the stock fuse is a 10amp, replace it with a 20-25 amp, and you should be straight...
jperkins012
01-12-2005, 06:27 PM
Which fuse? I can't find the fuse for my dashboard lights. Any help appreciated.
ajohnst
01-21-2005, 01:05 PM
I don't know if this is the problem, but there is possibly two locations for fuses. One is in the engine compartment and one by the steering wheel. Make sure you check both.
jsessums
09-10-2010, 01:17 AM
yes please help i have the exact same problem with no power to the pumps and i don't have a singal bad fuse all wires are good i even went as far to tear up the interior to check all the wires
