Audio System Specs for 1991-6?
vought
03-17-2001, 02:24 PM
Does anyone know the specs for the original Clarion audio system installed in the 1996 car? Amplifier wattage, etc?
SkylinesKillAll
03-19-2001, 06:53 PM
yea the front door speakers are 4x6s. the rears are 6 3/4 which are powered by their own 40 watt amps. it sounded pretty nice but i wanted louder so i put a system in :D
vought
03-19-2001, 07:05 PM
I replaced the rears with a pair of Infinity (really, they were the best price/performance) Kappa 625 speakers this weekend.
They are much better than the original Clarions, but are a little underpowered - although at typical volumes, they're fine.
Thanks again.
hotani
03-20-2001, 04:37 PM
i think the stock system sounds great - however, my cd player has recently crapped out. its funny because the colder it gets, the more it skips!!
Thinking about replacing it with another single cd head unit, but was wondering if anyone else has had this problem - even better: does someone actually know of a fix for it or repair costs?
vought
03-20-2001, 05:05 PM
My CD player occasionally refuses to auto-inject a CD, and I've got to eject and re-insert a few times.
If your CD player is skipping, try using a Cd lens cleaner disc. These are available at most stereo stores, and they've saved my butt once or twice. Typically, it's just a CD platter with a tiny soft brush on the underside that wipes dust from the lens. You may want to try this before replacing the head unit.
-D
hotani
03-20-2001, 05:22 PM
thanks for the suggestion, I'll have to try that.
Mine has the same problem you are describing as well, especially with CDR disks. they used to insert and play fine, but now I can't get them to go in and if it does, it skips too much to listen to...
NismoG20
03-20-2001, 08:58 PM
dude man just get a new cd deck... thats what i did and u can tell the difference even with the speakers! i promise!:smoka:
endfro
03-21-2001, 10:07 PM
Heh, you wanna know a good audio system in a 1991 P10 G20?
Check mine... retails for over $6500
Head Unit - Kenwood eXcelon "R" Stock (tweaked by Kenwood themselves) 817
Changer - Kenwood eXcelon 10 disc
Front Speakers - Audiophile 5" driver components w/ 1" tweeter in custom designed/built kickpannels in front door
Rear Speakers - Audiophile 6" driver components w/ 1" tweeters custom mounted in back dash
Subs - 3 JL Audio 12W6's
Front Channel Amp - Xtant 2200ixR
Rear Channel Amp - Xtant 2200ixR
Sub Amp - Crossfire BMF1000D
competition quality sound baby. i love my G20
BlackG20
03-24-2001, 08:01 PM
I would really recommend just going ahead and replacing your CD player and hopefully your speakers as well with some aftermarket stuff. I took out the clarion head unit and the sony add on CD player and put in a Panasonic head unit and a pocket deck to fill the CD players former home. It sounds great, I just have to fix a little fuzziness in the rear speaker, my friend and I suspect the amp. The CD player in my 1993.5 was just so bad with skips, if you like your music, it isn't worth it to keep it around.
NismoG20
03-24-2001, 09:25 PM
what do u mean by a pocket deck :confused: ... cause my g20 came with a cd player as the main unit and a tape deck.... and when i put my new deck in i couldnt use my tape plaer so its just sittin in there cause i dont wanna take it out and have a blank whole... so is a pocket deck like a compartment hole? if it is i want one dude! where can i get it???:flipa:
mattG20
03-26-2001, 11:52 PM
Just replace everything, like me!!!
deck: pioneer premier deh-720
front speakers: MB Quart PSC 5.25" seperates
rear speaker: MB Quart DKC 6.5" coaxial
sub: 12" MA audio MAW612
Amp: Rockford Fosgate 600a4 (2channels to sub, other 2 to front speakers)
Hits a tested 141db!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :devil:
bump909
05-10-2001, 11:46 AM
yeah, it's a change tray.. it's pretty convenient. try locating one at a junkyard, maybe you can get it for 5 bucks or so. just tell them it came out of a ford escort. :)
cliffud
06-03-2001, 03:48 PM
just a note on the skipping CD player in cold weather...
most likely- because it skips when the environment is cold, that suggests to me that the suspension system inside the deck is probably dirty.
the oils that have lubricated the innner workings of the suspension have probably become gummed up with dirt and dust... so when it's cold, the oils cannot lubricate as well... however- when it gets warmer... the oils begin to melt a little more and it starts to let the suspension travel with the undulations of the car as you drive... thus- allowing you to hear skip-free music.
solution: take out deck, open up and clean.
or- go buy a new deck... the difference will be phenomenal- higher fidelity, more wattage coming from the new deck, better looking interface... etc.
good luck.
----cliffud-p10----
cliffud
06-03-2001, 03:52 PM
you can get a pocket deck from your nissan dealership...
it will just be a place to put some CDs and it will look factory (because it is factory on some nissans)
good luck
cliffud-p10-1993
alpine cva 1000
dei 4000 crossover <<< installed under the climate control unit
rf punch 100.2/240.4
polks in front/pioneers in back
couple of mtx (got them cheap) 10'' in the trunk
and a playstation just for fun.
SR20detttt
07-04-2001, 06:28 PM
Whatever you do, keep it small and simple! You don't want to ruin the best part of the G20, its handling. Big subs and amps weigh you down! I would reccomend a nice deck, new speakers all around, and maybe a small sub if you need bass. Then either use the head unit for the speakers, or get a 4/5 channel, 5 being if you want a sub. Or get a Bazooka Bass Tube, or Infinity Basslink. You might want to go with the infinity, just so you can have an infinity in an infinity :)
