Re: KIA Sportage Routine Maintenance
the spark plugs are like in the hemis the are in the middle of the engine under the air intake manifold the there is about a two inch black cover you will haveto take the manifold bolts off and shimmy it a little up so that you can slide the top of of it but make sure you tighten all the bolts when you are putting them back because a few are ground points
