Program Codes for ML320
JohnS37075
05-08-2003, 03:36 AM
I had to replace the battery in my remote and now the darned thing will not work...How do I go about reprogramming it?????
Need some help ASAP :stormzap:
cassie
01-22-2004, 09:01 PM
You can take it to the dealer and show ID and they will assist you in programming it. Or if you are lucky, you can call the service department and someone will actually tell you how to do it. you hold the buttons down and you enter a number into the radio (or something like that). I did it once with the service guy over the phone. Easy to do. The most important thing is you must know the code for your car. Look in your manaul to see if it was written in there. Mine was.
Good luck!
peterschulle
02-14-2006, 05:06 PM
:shakeheadI had to replace the battery in my remote and now the darned thing will not work...How do I go about reprogramming it?????
Hey John - got the same problem - got any solutions yet? - I'm pretty
pissed, not only did the battery cost $167 installed - got no tunes --Peter
rattfink
08-29-2006, 07:38 PM
anyone who has this issue; put key in ignition, turn to position 2, turn ignition off, remove key, simultaniously press lock and unlock buttons, release unlock while holding the lock button and than press the lock button 5X (within 5 seconds), then test the lock or unlock buttons to confirm success. if it doesn't work, try it again, you probably waited too long. Dealer charges $50
vs5585
11-25-2007, 10:48 PM
by the way owner's manual say the same thing
hitronics
10-30-2008, 07:39 PM
put the key in the ignition turn one noch and wait 60 min it will program it self
