Reprogramming Keyless Entry
vassil3427
05-07-2003, 06:09 PM
I have a 2000 Oldsmobile Silhouette, I need the instructions on how to program new remotes to it. Thanks
IdahoEd
05-31-2003, 02:23 PM
I have a 1999 Silo and found the answer to reprogram in another thread.
Look under Chevrolet>Nonspecific>Keyless Entry Info
Check down the list for TIREBURNER. He has many listings but look for the reply to the same question as yours from a 2001 Pontiac Montana owner.
It is a listing of the GM's 1999 how to reprogram keyless entry units.
It will work for your 2000 Silo.
Make sure you do all your units, working or not, at the same time or the working ones will be disabled when you program a new one.
Good Luck
provfiredive
07-14-2003, 09:44 PM
I tried this w/ no luck. I can't seem to get in to the programing mode.
when i am done trying my original one still works, any other suggestions?
bwheeler
07-17-2003, 08:55 AM
I"m not sure if this will help or not but I stumbled across a similar thread in the GMC/Jimmy forum. There is a thread titled "remote reprogramming" you might want to read. Just a thought.
RoccoT
08-06-2003, 09:52 AM
Will these procedures work for a 93 remote entry? Or can anyone post the procedure for me?
Thanks
ekarasik
01-22-2006, 10:05 PM
I need the instructions for the 98 silo. If anyone has it please be so kind...
Onblsht
02-06-2006, 08:16 AM
97-00 use these:
Important! Once the BCM enters program mode, all transmitters must be programmed at the same time. Any transmitters not learned at this time will be erased.
1) Remove the key from the ignition cylinder
2) Remove the BCM PRGRM fuse from the fuse panel
3) Close all the doors
4) Close the liftgate
5) Turn the ign lock cylinder to the ACC. position
6) Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second
7) Open and close front passenger door
A chime will be heard when the system enters the BCM programming mode
IMPORTANT!
After 7 seconds a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
8) Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds
9) Repeat the previous step on each additional transmitter to be programmed.
10) Remove the ignition key from the ignition cylinder
11) Install the BCM PRGRM fuse back into the fuse panel.
provfiredive
02-06-2006, 08:43 PM
Step 6, should be changed from within one second to as FAST as humanly possible
This is what was preventing my reprogram
provfiredive
02-06-2006, 08:47 PM
Otherwise it work fine for a 1999 Silo
salinasd
12-30-2006, 03:18 PM
I have a 2001 olds silhouette
can anyone confirm the process for re-programming a new remote.
Thanks
DS
heasma02
06-26-2007, 10:22 PM
I am having trouble getting this to work. After step 6, i get one chime, then a pause, then another 8 chimes, a pause, then one chime, then a pause, then another 8 chimes, a pause and then it does the same again, for the third time. I then follow the rest of the steps, but to no avail. Can anyone help??
BNaylor
06-27-2007, 12:37 AM
Welcome to AF.
Sorry but please check the date and do not resurrect old threads. Furthermore, this one has run it's course. Start a new thread addressing your issue. Thread closed.
