1964 Parts WantedWashPaChris 64 05-07-2003, 01:16 PM I am looking for a power steering pump, pulley and mounting brackets that will work on my 1964 Impala with a 283 motor and short (5-inch) water pump. Also, I am looking for a power brake booster for the same vehicle. I know there are plenty of these available from retailers, but I am looking for junk yard or used parts. Thanks, Chris kandyintegra 06-05-2003, 01:14 PM Give this guy an email...James is a cool guy and located in Louisville, KY...I have bought several parts from him...He has a Impala Junk Yard with many 64 parts to choose from impalaparts@aol.com If he doesnt have them, You can always try Hubbards Impala Parts or Impala Bob's facilitator 07-27-2003, 08:35 AM Hi, I have the mounting bracket for the power steering pump and the pully as well. Let me know if you are still in need of these parts. Roxann WashPaChris 64 07-27-2003, 11:18 AM i NEED THE PULLEY THAT MOUNTS DOWN ON THE MOTOR WITH THE ALTERNATOR PULLEY DO YOU HAVE THAT ONE? facilitator 07-27-2003, 12:57 PM Are you asaking for the pully that goes on the alt. and the pully from the power steering pump? I have all the pullys of the engine and the power steering pump and mounting bracket as well. WashPaChris 64 07-27-2003, 07:39 PM I have the pulley that is connected directly to the pump. I need the one on the other end of the belt that connects it to the motor. WashPaChris 64 07-27-2003, 07:42 PM Here's where I need the pulley. On the harmonic balancer. facilitator 07-27-2003, 10:04 PM The pulley I have is a doubble pulley as this car had air as well as power steering. I may have a singal pulley I will look. WashPaChris 64 07-28-2003, 09:52 AM Cool... Thanks. The picture I showed is what I currently have. The only belt on my car is for the alternator. Does the power steering pump drive from a separate pulley on the harmonic balancer or do i just have to put a longer belt on to use the existing pulley to drive the alt and ps? If I bought your double pulley, I would then Have essentially 3 pulleys on my harmonic balancer, correct? The one with tha ac would be ok too as I may decide to do something with it at a later date. Automotive Network, Inc., Copyright ©2012
