2000 Chevy Tahoe Limited Keyless EntryTHART 05-06-2003, 11:36 PM IF HAVE HAD MY 2000 CHEVY TAHOE LIMITED FOR ABOUT A MONTH AND A HALF NOW AND JUST NOTICED WHEN I PRESS LOCK ON MY KEYLESS ENTRY REMOTE IT ONLY LOCK MY 4 SIDE DOORS AND LEAVES MY BACK TAILGATE DOORS UNLOCKED! IF I PRESS THE REAR 2X BUTTON ON MY REMOTE IT UNLOCKS THE REAR BACK DOORS, IF THEY WERE LOCKED WITH THE KEY. I WAS WONDERING IF I REPROGRAMMED THE REMOTE WILL IT LOCK ALL DOORS? TIREBURNER I HOPE YOU CAN HELP ON THIS ONE THANKS BEFOREHAND T. HART:smoka: BY THE WAY IT THE OLD BODY STYLE Shortbus 05-12-2003, 01:26 PM The Lock button should lock all exterior doors. If not then there is a problem with a component, and reprogramming the transmitter will probably not help. Here is an Exerpt from repair manual, The procedure is all jumbled up because the copy and paste does not keep everything in order.. sorry Door Lock Inoperative with Transmitter - All Step Action Value(s) Yes No DEFINITION: This diagnostic procedure should only be used if the power doors lock with the power door lock switches and are inoperative with a keyless entry transmission. 1 Did you perform the Remote Keyless Entry System Check? -- Go to Step 2 Go to Remote Keyless Entry System Check 2 Disconnect the remote control door lock receiver connector. Connect a test lamp between cavity R and ground. Press the LF door lock switch to the lock position. Does the test lamp light? -- Go to Step 3 Go to Step 4 3 Replace the remote control door lock receiver. Refer to Remote Control Door Lock Receiver Replacement . Is the repair complete? -- Go to Remote Keyless Entry System Check -- 4 Repair the open in CKT 195 (LT BLU) between the remote control door lock receiver and S261. Refer to Wiring Repairs in Wiring Systems. Is the repair complete? -- Go to Remote Keyless Entry System Check -- -------------------------------------------------------------------------------- Automotive Network, Inc., Copyright ©2012
