How much boost?
Pages : [1] 2
alessandro
05-05-2003, 11:34 PM
I'm planning on doing a whole engine work on my B16A2. I am planning on installing Toda Pistons, Eagle Rods, JG Edelbrock Intake Manifold, Skunk 2: Camshafts, Springs, Retainers, Spoon Valves, P&P and RC Engineering 310cc Injectors.
If I do install all the parts listed I was wondering how much boost will I be able to run? By the way my turbo kit comes with a Garrett T3/T4 Turbo.
Also any advice on what things I'm missing, or other parts that could be better will be appreciated.
Thanx!!
MARKUSIUDIUS
05-06-2003, 05:53 AM
One thing you are missing is the computer to run the goodies. Id say start at 12psi and see how it feels remembering that safe boost is the best way to begin.
All the best :flash:
P.s After the first run screw in another 8psi it should be fun.
TrailerParkJake
05-06-2003, 06:10 AM
if youre planning on running a lot of boost, id suggest going with larger injectors than the 310s your planning on, so you dont have any problems with them not providing enough fuel.
also stay away from the aggressive NA cams if youre boostin, theyre gonna rob power from ya
PWMAN
05-06-2003, 09:48 AM
Thanx!!
Up to 14 PSI because thats all the stock sleeves will handle. Now, if you get it sleeved you should be able a handle 20, what brand of turbo kit are you getting?
Also do what TrailerParkJake said and get bigger injectors and no aggressive cams, get cams specifically for turboing.
Oh and one more thing, just get the Skunk2 manifold instead of Edelbrock. It does just as good and costs a couple hundred less.
casperGSR
05-06-2003, 08:43 PM
Thanx!!
leave your stock camshafts and valves... using 310cc injectors you should be able to run upto 10 lbs without having to worry about running lean anything higher though the injectors won't be able to keep up... what kinda fuel management do you plan on using? personally if you're gonna replace your internals you might as well have it resleeved while you're at it...
alessandro
05-06-2003, 08:45 PM
thanx for the help, ok so if the Skunk2 intake man. will do the same for less then that's the one :p .
For the computer, what do you think about the Hondata S100 w/boost.
Any opinions?
For the cams which one should I get, I was thinking maybe Toda or Crane let me know what you think.
And about the boost, I just want to know how much top boost will I be able to run, just so I can regulate it.
Thanx
PWMAN
05-06-2003, 09:11 PM
Any opinions?
Thanx
Leave your stock cams like CasperGSR said, you want the least agressive possible. Or buy a cam that is specifically for turbo with the duration on the exhaust a little less so it spools the turbo faster. Gude has good cams but I think they are expensive, not sure though on the price of Toda.
What kind of compression are you running, then I can tell you how much boost.
Oh and good choice with the Hondata.
alessandro
05-06-2003, 09:22 PM
Right now it's stock compression, 10,6:1. But when I install the new pistons, the compression will rise to 12.4:1.
There's a Skunk2 Camshaft specifically for Turbo, the same for Toda.
I don't have prices with me right now.
94tegRS
05-06-2003, 11:01 PM
with 12.4 it is gonna take VERY good tuning to handle anything above 5 psi.
just stay down around the 10's to 1 cr, then you could handle a fair amount of boost, I dint know much about how much boost certain setups will handle but I know 12.4 is way to high to run high boost levels.
alessandro
05-06-2003, 11:17 PM
Yeah I was thinking the same, but what would be better, having this high compression pistons and low boost, or to have lower compression pistons and more boost?
I've seen a set of Crower Pistons at 10.9:1
Thanx
alessandro
05-07-2003, 11:17 PM
bump :p come on help me out here :D
Neutrino
05-08-2003, 12:31 AM
Thanx
go with low compresion and high boost. ad boost to a 12.5:1 compresion and you will be beging for detonation.
the evo for example uses 8.8:1 compression.
alessandro
05-08-2003, 12:39 AM
I see, thanx a lot for the help!. Hey nice car in your sig, but I couldn't help to notice, excuse me if I'm being ignorant but isn't it a Ford? why under your name it says Mercury? :confused:
94tegRS
05-08-2003, 01:05 AM
its ford motors, but badged mercury. you now, like lexus-toyota, nissan-infiniti, honda-acura, ford-lincoln-mercury, dodge-chrysler-plymouth, chevy-gmc-geo.
I think ford even owns jaguar now, and owns volvo. shit, I bet in another 20 years every cars coming from one name.:rolleyes:
Neutrino
05-08-2003, 01:42 AM
yeah that would be correct. they are badged mercury in the US.
also you are probably right in 20 years there will be only one car company.:(
alessandro
05-08-2003, 08:11 PM
Let's hope not!
Ok returning to my question, I can get 9.5 or 10.5 compression pistons, will I be able to run more than 13 boost with them?, considering the other engine mods that I'm planning.
Thanx!
PWMAN
05-08-2003, 09:55 PM
Let's hope not!
Thanx!
With 9.5 pistons you can only run about 10 PSI. With 10.5 pistons only 5-6 PSI, with extremely good tuning. But if you got 9:1 pistons you can run about 14. You only loose like 5-10 HP for every .5 compression, but you can boost more to make up for it plus gain even more.
How much octane is your high test gas where you live, 93 or 91?
1320B4U
05-08-2003, 10:20 PM
You should choose high boost or high C/R. Why try to mix two completly different setups for the street without the benefit of C16+ octane. I mean NA uses lighter(weaker) rods and pistons(domed), while turbocharging you need heavier stronger rods and pistons(dished) to handle the immense cylinder pressures. Honda drag cars don't even use VTEC on their engines, they disable it. Say your turning a B16 with its near perfect 1.74 R/S ratio into a high boost engine 20psi+ (forged internals, turbo cams, big turbo, FMIC, 550cc, Sleeve or blockgaurd?, etc...), so with the turbo cams, VTEC isnt going to work, so how do you go about disabling it?
alessandro
05-08-2003, 10:59 PM
I think I would go with high boost, so the 9.1 could be the ones, the highest octane fuel available here in Peru is 97
I don't think I'd disable VTEC cause I'm not planning on going full drag or racing, you say that with the Turbo Cams, VTEC will not work? In the description it says "VTEC DOHC Turbo" If what you say is correct then I'll have to think, either to keep the stock cams or to put on Turbo Cams and disable VTEC :confused:
PWMAN
05-09-2003, 11:19 AM
WOW 97 octane, that must be nice. You can probably run about 18 PSI on the 9:1 pistons with 97.
Just use your stock cams, turbos apps for the street don't like big cams. With 18 PSI you going to make a lot of power, so forget about the cams, don't waste your money.
alessandro
05-09-2003, 04:49 PM
yeah it's pretty cool but pretty expensive too (around 40 bucks to fill the tank) but I don't have gas problems cause one of my grandfathers owns some gas stations and let's me refuel for free :sun:
I was wondering how much is the gas in the USA and what's the higher octane available?
And about the cams, yeah I think I'll just leave em stock
PWMAN
05-09-2003, 06:02 PM
In my particular area the highest is 93 Octane. Out in California it's 91 I think. I heard some places having like 101 octane unleaded, but it's like 3.50 a gallon or something like that. Here currently in my area of Pennsylvania the prices are like 1.36 for 87 octane, 1.47 for 89 octane, and 1.59 for 93 octane. You can get racing gas called CAM2 its like 114 octane but it's leaded and will clog Cat. converters and fry O2 censors. And also you cannot fill your car up with it, you have to put it in gas cans and take it away - environmental reasons cuz of the lead I guess.
alessandro
05-09-2003, 06:29 PM
oh that sucks... well here in Peru we are more free from those kind of laws so we can mostly do whatever you want to your car, the cops don't bother that much.
A question, you know where Peru is right :p ? It's just because there are a lot of people in the USA that don't what Peru is. :bloated:
Returning to my car, there were some other things that I had to look, will 440 cc Injectors do? and what about a Ignition Module? I was thinking maybe the HKS Twin Power Distributor or Crane Cams HI6.
Oh and by the way I'm getting 9.9 SRP Racing Pistons, hope fully I'll be running good boost
94tegRS
05-09-2003, 07:22 PM
here in WA, it is 92 octane and its like 1.79, a couple places it is 93 octane though.
and if you go to crower.com, they can make any compression you want for 80 bucks more. but sounds like you already ordered
alessandro
05-09-2003, 07:43 PM
No I haven't ordered yet, but you think that ordering some 9.5 compression pistons would be worth it? I mean would the boost be worth the 80 bucks?
94tegRS
05-09-2003, 09:01 PM
well, I dont know, but just telling you you can get whatever you want. but the higher you go, the more power you have while the turbo spools
PWMAN
05-09-2003, 09:41 PM
Thats true but in turn the more boost will far out weigh the losses of that power. Like the difference between 9.5 and 9 CR horsepower wise is only like 5-10 HP. But going from 9.5 to 9:1 you will be able to boost about 4 more PSI, which will make like 30 HP. Get what I'm sayin? Loose 10(if that) to gain 30.
94tegRS
05-10-2003, 12:39 AM
yeah, I do now. I just thought it was like the cylinder cpould take a certain amount, so if your engione compressed the air more then the air coming in had to be compressed less, and if you had low compression youcould compress the incoming air more so that in the end either way you had the same pressure in the cylinder and about the same power. but I guess I was way off.
alessandro
05-10-2003, 03:21 AM
Ok thanx I got everything clear now. I think I'll go with the 9.1 Comp. ones. I'll just have to find other ways to reduce turbo lag.
There are some other things that I had to look, will 440 cc Injectors do? and what about a Ignition Module? I was thinking maybe the HKS Twin Power Distributor or Crane Cams HI6.
PWMAN
05-10-2003, 07:07 PM
Depends on how much power you are making.? I'd say that the 440 CC injectors will support somewhere around 300 HP. So with 18 PSI you are right around that area cuz you will probably atleast double your horsepower and make somewhere around 320 HP. If you wanted to stay on the safe side run 16 PSI, and you will probably be right at 300 BHP.
Oh and about your ignition module, I would go with MSD, they are really good.
alessandro
05-13-2003, 12:35 AM
ok then all of that is clear, now another question has arisen. :confused:
Will I need a Boost Controller? and also, where does it plug into and how does it control the boost?
Also I got today my Apexi Coilovers and are being installed alongside Ingalls Camber Kits. It's gonna be ready hopefully tomorrow afternoon, I can't wait to test it!! :D
casperGSR
05-14-2003, 07:49 PM
a boost controller is a good idea to get if you want to be able to adjust your boost levels depending on if you're on the street or at the track... you can get a manual boost controller for relatively cheap, assuming you have an external wastegate it can hook up directly to that. As far as the compression on the pistons I don't think you're gonna be able to find a 9.0 to 1 compression that easily, I looked all over for them for my b18c1 and the lowest I was able to find was 9.5:1 by JE. Personally I'd say do some darton sleeves and je's with either crower or eagle rods... just my opinion.
94tegRS
05-14-2003, 08:07 PM
srp 9.0:1 for B16 http://www.crower.com/cgi-bin/detail.cgi?prod_id=99449
casperGSR
05-14-2003, 08:23 PM
they don't make them for a b18 though do they? I thought that's what he was running, didn't realize it was a b16.
casperGSR
05-14-2003, 08:26 PM
maybe if I looked at his sig I would have seen it has a b16.:silly:
casperGSR
05-14-2003, 09:18 PM
see kids this is what happened when you've done too many drugs in your life... you start to forget what exactly you have put into your car, I'll correct myself b4 anyone else does, you can get 9.0:1 compression pistons for b18's cause that's what i have, not 9.5:1... :thinkerg: you should never be under the influence of drugs when driving, and apparently I shouldn't be online. :smoker:
alessandro
05-14-2003, 11:21 PM
LOL, that was funny.
Yeah about the pistons I'm getting SPR with Crower rods, about the resleeving I'm still checking around.
Ok, a manual boost controller connects directly into de external wastegate, and what about an electronic one? does it hooks up to the wastegate too?
Rob80
05-16-2003, 06:19 PM
Is there much of a difference besides price between the srp pistons and the JE pistons? Cause JE doesn't have drop ins for a b18b, and I found the srp's for like 320 shipped with rings, which is dumb cheap. If anyone knows help me out thanks.
Rob80
05-16-2003, 08:31 PM
super_man_3179
05-31-2003, 11:00 AM
OH NO!!!!! PLEASE TELL ME YOUR NOT GOING TO TRY TO RUN 18 LBS OF BOOST ON A 12.5 COMPRESSION RATIO!!!!!!! WHAT THE HECK MAN!! U NEED TO LOWER THAT A WHOLE LOT!!!!! YOUR GOING TO HAVE TO RUN RACE GAS AND HAVE SOME ULTRA TUNING AND AN ENGINE ON STEROIDS WITH SUPER SLEEVES AND PISTONS TO BE ABLE TO TUNE THAT!!! IT WILL NOT BE A DAILY DRIVER AFTER THAT. YOU WILL PROBABLY BE PEELING OUT AT 1000 RPMS....LOL!!!!!
94tegRS
05-31-2003, 04:17 PM
I agree with you about the compression, but at 1000, which is about idle, I doubt there will be ANY boost. so no peeling out there.
PWMAN
05-31-2003, 05:28 PM
SRP pistons are not made for FI applications. SRP pistons are made by JE pistons company. The SRP are supposed to be all-motor and JE are for turbos. SRP pistons will not handle any more boost than stock pistons, meaning 12 PSI. More than 12 and they will melt, this is why they are so cheap-because they SUCK!!!:flamer: SRP
alessandro
06-01-2003, 02:35 AM
sorry I couldn't answer earlier, I had my pc taken away because some damn virus busted up some things...
about running with 12 comp, that was before, now I'm planning on buying Wiseco 9.0.
4bngr
06-01-2003, 05:42 PM
Turbo motors love high lift with short duration. so finding a set of cams would help. Definetely would sleeve to block while I'm in there, also, 310cc injectors are way to small, i personally would go with 550's. I woould start at 12p.s.i. better to be safe than sorry, becuase unless you are loaded, it would be a real bitch to replace what you had just completed.
alessandro
06-01-2003, 06:38 PM
I'm gettin 440 cc injectors.
I'm still somewhat confused about the cams, I was adviced to keep the stock cams, I'm not really sure yet.... any help?
4bngr
06-01-2003, 06:44 PM
The stock cams are alright for moderate power levels, 200-300hp. But for the most noticable difference, a set of cams with high lift and short duration is the way to go, they allow more power to be made in the mid and upper power ranges, while reatining a somewhat stock idle.
super_man_3179
06-01-2003, 09:43 PM
Well then what forged pistons can you get on a b18A motor that will keep stock compression ratio?? 9.2:1 ???
PWMAN
06-01-2003, 10:00 PM
JE 9:1 is close enough. If you really want 9.2:1 than just mill the head a little.
sameintheend01
06-02-2003, 01:00 AM
about the 97 octane.....his 97 octane is not comparable to our 97 octane. i know europe uses a completely different formula for calculating octane (something about rons or mons or something) and im sure peru would be differnt from the usa too.
PWMAN
06-02-2003, 07:44 PM
Yeah your probably right.
outsidethebox
06-02-2003, 09:14 PM
If you want to run a lot of boost, your going to have to go lower than 9.0 or your going to have to run race gas on the street, which almost no one can afford to do. USA octane compares to no one elses.
As an example, the new Subaru STi makes 300 hp on pump gas, at 15psi boost, and also uses variable valve timing (vtec), but thousands of hours of development time under laboratory dyno conditions were used to acheive this with the kind of dependability you need in a street car. And it has a compression of 8.2 to 1. It also has an intercooler with water spray, specially designed combustion chambers and tumble generators for more swirl in the chamber, all of which helps control detonation. Water injection would help, but if it fails to work, you'll detonate. Read this. http://sdsefi.com/techocta.htm
PWMAN
06-02-2003, 09:48 PM
I'm running 8.5 PSI of non-intercooled boost in my Daytona right now on 89 octane with 8.5:1 compression. No knock or ping. T2 intercooled daytonas run 12 PSI intercooled boost stock on 8.5:1 compression and it says to run ''unleaded regular''. The only reason I run 89 is because 87 has a whole bunch of floating crap in it that clogs fuel injectors. 89 is clear as can be.
Neutrino
06-03-2003, 02:47 AM
the sti system is not Vtec type...its only variable timining not lift too....big difference....also the sti is not even close to be as extremely tuned as the evo with 8.8:1 and running 19 psi
Cronic
06-03-2003, 04:57 PM
the STi will walk all over the Lancer, US versions anyway.
Neutrino
06-04-2003, 12:01 AM
you have not read any reviews have you....the evo manages to take down the sti due to better handling......true by a narow margin but it still manages
1320B4U
06-04-2003, 04:28 AM
www.buschurracing.com has an EVO 8 running 12.6 sec @19psi
Neutrino
06-04-2003, 05:48 AM
wow they must have done that just trough tunning sice the evo is running stock 19 psi
Cronic
06-04-2003, 07:19 AM
I really don't see 19psi being the stock boost setting. I'll have to do some digging. Do you have a like to where you saw this?
Also, the Lancer's transmissions have always sucked, the outside is horrid in comparison, and it has 30 less bhp then the STi.
PWMAN
06-04-2003, 08:25 AM
29 less BHP, get it right! J/K LOL
Anyway, the AWD system of the STI takes away alot of HP. So like I said before, from a rolling start say 60 MPH they are probably going to be pretty even.
Cronic
06-04-2003, 08:33 AM
SRP are both for turbo and all motor apps. Why would you get low compression all motor? I have JE SRP pistons in my D series motor. 9:1.
IMHO however, JE pistons suck. They're tolerances are only .01" Which is shit compared to other companies such as Wiseco/Endyn/Arias which are closer to .001".
Just personal preference however. My SRP's have held up well in VERY unfavorable detonating conditions. Only the valve reliefs seem to have taken any damage from detonation, and a little sanding will cure the hotspots.
