Keyless entry
03RedMatrix
05-04-2003, 05:03 PM
Can anyone help me find out how to program the keyless entry (GQ43VT14T) for a 2003 Toyota Matrix?
Thanks,
michael runyon
08-16-2003, 11:02 PM
go to your local toyota dealer. they will usually program the keyless entry for free. it actually should have been done when the car was preped for delivery to you so theres no reason they should charge. since i work for toyota im reasonably confident that thay will take care of this at no charge to you
Big Dooky
05-17-2005, 12:38 AM
Program Remote for 2002 Camry (and perhaps other Toyotas with same remote)
1. Start with the key out of the ignition, driver door open and unlocked
2. Insert the key and take it out - twice within 5 seconds
3. Close and open the driver door - twice within 40 seconds
4. Jump out and run around the car once as fast as you can (optional)
5. Insert the key and take it out – once
6. Close and open the driver door - twice within 40 seconds
7. Insert the key and close the driver door
8. Turn the ignition to “On” hold it for 1 second, turn to “Off” (for “Add” mode)
9. Remove the key
10. Hold down both “Lock” and “Unlock” at the same time for one second
11. Press “Lock” within 3 seconds.
(If the signal was recognized the locks will cycle once, if not they will cycle twice.)
You can program a maximum of 4 remotes. Do a fifth and you’ll loose the first.
To see how many are programmed: on step 7 switch between on and off (holding 1 sec in each position) 3 times. The locks will cycle once for each remote that is programmed.
To erase all programmed remotes: on step 7 switch between on and off (holding 1 sec in each position) 2 times. (Say if you are replacing a lost or stolen remote)
To erase all programmed remotes and disable the remote key entry system all together: on step 7 switch between on and off (holding 1 sec in each position) 5 times.
