tachometer not working propley nissan r32 gts-t rb20detchooksta 05-04-2003, 11:03 AM me agian, my tacho is flickering on and off and i was wondering if any one else has had this problem? does any one have a wiring diagrame? where does the signall come from? the crankangle sensor? :flash:my car is a nissan r32 gts-t 1993 RazorGTR 05-04-2003, 12:59 PM It sounds more like the joint where the cable runs into the back of the cluster is split. I've seen this on a GTS4. If you remove the instrament cluster and then the cable out of the back of the dial there is a plastic coupler that it runs into. You may be able to source a second hand one from a wreckers as I am not sure you can still get them from Nissan new. chooksta 05-05-2003, 10:55 AM hi thank 4 your reply, do you mean the cable for the speed meter (kph) or are you talking about a wire or connection if it is a wire can you remember the colour? thanks:flash: Automotive Network, Inc., Copyright ©2012
