Real simple solution for you here.....
Injectors for 98% of all turbo cars are "Peak and Hold" Internal resistance is around 3 ohms , which makes them very quick reacting , as would be required by coming up on boost and falling off boost , which happens very quickly.....
Injectors for NON-turbo cars are "Saturated" , internal resistance is typically 30+ ohms...
These injectors CAN NOT be mixed and matched with other ECU systems without appropriate precautions. The 3 ohm turbo injectors when plugged into an NT ECU....would simply MELT internally. The opposite would be true plugging NT injectors into a turbo ECU would burn up the ECU....its not designed to push that kind of power.
Otherwise , good luck on your conversions
