| Latest | 0 Rplys |
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
03-06-2010, 08:30 PM | #1 | |
1994 high Idle
I just bought a 1994 eagle talon. I put a new battery and a used 5 speed tranny. When I started it, it was running at 2000rpms and after it warmed up it started going from 1500 to 2000 up and down. So I added coolant. It worked. The car went down to 1500rpms. but its still at high idle. I adjusted the idle screw all the way. also the coolant light is on. I think its the Idle speed sensor, coolent temp sensor, or the tps. If anyone has had this problem please help. Thanks.
1994 Eagle Talon 2.0 DOHC 5 speed. |
03-07-2010, 10:35 AM | #2 | |
Dave is THAT guy
Re: 1994 high Idle
Welcome to AF!
I would buy a Haynes manual and look at the proper way to test the IAC. Low coolant should not affect idle at all (unless it's overheating), and that seems to be a seperate problem. The manual will show how to check for proper resistance, and then how to replace. The high idle could also just be a result of a dirty throttle body, bad throttle body gasket, or a vacuum leak.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
03-07-2010, 12:06 PM | #3 | |
Re: 1994 high Idle
I checked for vacuum leaks and nothing. I will clean the throtle body it was a little black in there. Its also not over heating. Ill keep you posted and thanks for the help.
03-08-2010, 10:09 PM | #4 | |
Re: 1994 high Idle
It was the isc.
