| Latest | 0 Rplys |
02-23-2010, 09:54 PM | #1 | |
putting transfer case in neutral?
hello, i have a 1997 z71 with push button 4x4, it has 2hi 4hi 4lo, no autoshift. does anyone know how to put the transfer case in neutral. i dont have the owners manual and the dealerships here are very un- cooperative, thanks
02-24-2010, 12:42 AM | #2 | |
Re: putting transfer case in neutral?
If it has pushbutton and neutral isn't listed then you're out of luck :\
02-24-2010, 08:45 AM | #3 | |
AF - Advisor
Why do you want neutral on it or to put in neutral?
02-24-2010, 08:47 AM | #4 | |
Doesn't putting it in 2Hi automatically put in in neutral?
Frank 1998 Silverado Z71 |
02-24-2010, 09:15 AM | #5 | |
AF - Advisor
02-24-2010, 09:53 AM | #6 | |
Guess I didn't understand the OP. Putting a transfer case in neutral will prevent you from going anywhere? Thought in 2Hi only the rear wheels were engaged.
02-24-2010, 06:44 PM | #7 | |
Well you got a lot of replies but no good answers.
So here it is out of my '98 Owners manual. Your '97 may be different. Start the engine. If that's not an option then turn the key to the RUN position. Make sure the t-case is in 2HI and the switch light for 2HI is on and steady. Press and hold both the 2HI and 4LO buttons for at least 10 secs. The NEUTRAL light should come on. Put the tranny lever in REV for one second and then in DRIVE for one second. Hope this works for you.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
02-24-2010, 07:00 PM | #8 | |
The T-Case is the final drive to both the rear and front. So with the t-case in neutral you can put the tranny in any gear you want and you won't "leave home".
02-25-2010, 07:18 PM | #9 | |
thnks for the replies, especially you stickman, i tried that and it didnt work. the reason i wanted to put it in neutral is because i got a loud whining noise at 40+ mph, i put the rear end on jackstands and removed the rear driveshaft, had my wife get in and run it to 45mph (as my dumbass) got underneath it to try to find out if it was the tranny ot the t-case, i couldnt tell though. so if im able to put the tcase in neutral and the noise goes away i no its coming from the tcase, if not then i know its the tranny, so rite now im kinda stuck guessing which one it is. stickman, does your pushbutton have a neutral light for the tcase? mine doesnt just a light for 2hi, 4 hi/lo, but there would have to be a way to put it in nuetral right? in the event it had to be towed? thanks again guys.
02-25-2010, 09:28 PM | #10 | |
Ya my '98 Sub has the Neutral light. It is just to the left of the buttons. I also have the Auto 4WD t-case. I think you have to score an owners manual for your truck to figure it out. Maybe try a junk yard for one or a buddy. Also try a google search.
Good luck.
02-26-2010, 08:55 AM | #11 | ||
AF - Advisor
To tow it place in 2W and lift rear off ground or remove rear drive shat. Good luck
02-26-2010, 04:35 PM | #12 | |
Did some research for my own info and found the a '97 with the NP1 t-case has no provisions for putting it in neutral.
02-26-2010, 06:01 PM | #13 | |
thx guys, u r great. stickman thx, thats what i was thinking about no neutral, i just couldnt get hold of the info, thx again guys
