Go Back   Automotive Forums .com Car Chat > Ford > Escape | Maverick | Escape Hybrid
Thread Tools Search this Thread
Old 11-13-2009, 11:58 AM   #1
jhr323
P1406 & Rough Engine
Hi. My 2001 Escape 146000 miles just developed a rough engine and no power. OBDII says P1406. Any first guesses? DPFE valve? How do I check? Anything else to look for?
Looked for loose hoses and found an open rubber hose looped up to near the top of the ATF fill tube. It's secured with a clip to the fill tube but just loops around and back down with no termination. Is this normal?
Thanks for any help!
jhr323 is offline   Reply With Quote
Old 11-14-2009, 04:47 PM   #2
danielsatur
Re: P1406 & Rough Engine
A bad EGR valve or gasket can act like a broken vacuum line on a Intake.
The PCU & engine doesn't like unmetered air, so DTC's will be thrown.
Some Technicians will use a smoke test, others may use a spray brake cleaner to pin point umetered air leaks, while the engine is running.
danielsatur is offline   Reply With Quote
Old 11-14-2009, 07:01 PM   #3
jhr323
Thanks for the reply danielsatur. This thing clears up then re-appears in a day or so.
In your opinion would a bad DPFE sensor cause, in itself, a bad loss of power?
Thanks again!
Old 11-15-2009, 11:08 AM   #4
danielsatur
Do a Google ''Ford drive cycle''
It will take a little time + miles to throw a code!
Old 11-15-2009, 11:11 AM   #5
jhr323
Yes, it has thrown a code P1401. However, do you think a bad sensor would cause an extreme loss of power?
Thank you danielsatur
Old 11-15-2009, 11:22 AM   #6
danielsatur
1) Visual inspect for unmetered Air leaks.
The rubber hose looped near the AFT tube?
I always look for plastic (Air duct), rubber, and seals for PCV + EGR systems, that can go bad after 9-years.
The EGR + DPFE is probably good, it just probably a bad gasket or seal.
See http://www.automotiveforums.com/vbul...d.php?t=768631
Bookmarks
Search this Thread:
