Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 11-09-2009, 04:35 PM   #1
atxjax
atxjax Normal reputation
96 Plymouth Voyager stalling once warmed up.
This is for a friends grandma who is the widow of a WW2 vet. She is 85, still strong and likes being independant. Her minivan has gone tits up and my buddy and I are trying to fix it for her.
Its a 96 Plymouth voyager 2.4L automatic about 115K miles, doesnt smoke and is overall in very good shape. We get a code 43 when we scan the ECU for codes.
Starts fine, and runs good when cold, idles and sounds great until it reaches operating temp. Once it gets warm it misfires, hesitates, stumbles and shakes horribly. On the dash we can get it to flash a code 43 which means its getting a misfire. We can't drive it to autozone because it might leave us stranded.
So far we have checked all the vaccuum lines for leaks, checked the intake manifold for leaks with carb spray, changed the camshaft position sensor, changed the spark plugs, checked the plug wires for nicks and or cuts, checked the coils, and cleaned out the IAC valve. One thing strange about this vehicle is that we could not find the EGR valve.
What I am guessing is that one of the sensors is throwing it off once the computer takes over to control the emissions, hence why it only does it when its hot. I hate to have my buddy start throwing money at it randomly since we already replaced the camshaft sensor at $75 bucks and that wasnt the problem.
Weve been reading online and some folks say its the MAP, some say its the O2 and some say it could be the coolant temp sensor. Some folks say on this site it could be a bad alternator choking down the battery.
Im puzzled by this. Any help would be appreciated.
atxjax is offline   Reply With Quote
Old 11-09-2009, 05:42 PM   #2
RIP
AF -Advisor
RIP's Avatar
RIP Normal reputation
Re: 96 Plymouth Voyager stalling once warmed up.
No EGR on the 2.4 ltr engine. Do your best do get a scanner on it. A MIL code 43 equates to 10 different scanner codes that can narrow down the problem in seconds. If that's impossible try to determine which cylinder or cylinders aren't firing. Connect a timing light to each plug wire and look for the missing flash. Disconnect each plug wire one at a time and see which doesn't change the idle. If you want to keep swaping parts find a donor at a junkyard.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
RIP is offline   Reply With Quote
Old 11-09-2009, 05:51 PM   #3
atxjax
Thanks for the reply. I'm goign to have to get some software on my laptop and convert it into a scanner to try to narrow it down since I dont really want to drive it and get stranded. Here are the things I'm going to check...let me know if Im way off base.
1. Check the Temp sensor ( should be over 1K ohms cold ) about 400 warmed up.
2. Check the alternator. Should output about 14 volts when turned on at about 3K RPM
3. Change the fuel filter ( since its cheap and should be done anyway )
4. Do a fuel pressure test ( should be about 50PSI )
Anything else?
Old 11-09-2009, 06:18 PM   #4
jpb53
jpb53 Normal reputation
If you can; look at the old plugs and see if there is carbon tracking down the sides. If so you need to replace the plug wires.
jpb53 is offline   Reply With Quote
Old 11-09-2009, 06:20 PM   #5
atxjax
Only thing I saw on the old plugs were a brownish colored ring around the end tip of the wires. I think if the wires are bad it would run like crap all the time. Not to say that they arent....
Old 11-09-2009, 06:25 PM   #6
jpb53
This site give a different description of a code 43http://www.troublecodes.net/chrysler...20253335.shtml
Old 11-09-2009, 06:33 PM   #7
atxjax
Could be a bad coil that messes up once it is hot. You neve rknow. I would need to find a manual to test that coil.
Bookmarks
Google
Web AF
