Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Civic > '88 - '91 Civic / CRX
'88 - '91 Civic / CRX In association with DownToGround.net.
Old 11-08-2009, 11:56 AM   #1
stanlam
stanlam Normal reputation
91 Civic HB smoking.
I have a 91 Civic HB that was smoking(D15B1). Did a compression check and numbers were very low. Pulled apart and done a ring job. Head was cleaned up at the local machine shop(replaced a valve ) New head gasket also. Reinstalled and was smoking even more.Looks like white smoke.Changed out lower end with a D15b7 using the D15b1 head and the DPFI intake. New head gasket and intake manifold gasket. Running smooth and good compression numbers but still smoking. I let it run for 20 minutes and brought RPMs up.( smoking like a freight train) Finally got a fault code #1 for O2 sensor and engine started surging. I dont know the capatibility between a B1 and a B7. Can I put the B7 top back on the bottom and run DPFI left over from the b1 that was in there with the b1 ECU ? I would like to get my little car back up & running. Any help or insight would be greatly appreciated.
stanlam is offline   Reply With Quote
Old 11-08-2009, 04:23 PM   #2
Tony
神を選&
Tony's Avatar
Tony Normal reputation
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
Re: 91 Civic HB smoking.
Should be able to swap the intake manifold over to keep the DPFI.
Tony
Tony is offline   Reply With Quote
Bookmarks
Google
Web AF
