Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 11-07-2009, 04:13 PM   #1
joe110860
joe110860 Normal reputation
power windows
Someone Please Help. Both drivers side and passanger side windows don't work won't go up or down . the rear vent windows do work . Use to have to play with the switch to get them to work now they don't work at all. I replaced the switch in the drivers door and still no luck. I also can not find the fuse to the windows.
joe110860 is offline   Reply With Quote
Old 11-07-2009, 05:28 PM   #2
wafrederick
Banned
wafrederick Has more negative feedback than positive
Re: power windows
What year?I believe 1999 and up,you have to replace the regulators as an assembly since the tracks are plastic and break.
wafrederick is offline   Reply With Quote
Old 11-08-2009, 01:43 PM   #3
joe110860
Re: power windows
It is a 2000 kinda hard to believe that both regulators would go at the exact same time
Old 11-08-2009, 02:04 PM   #4
wafrederick
Banned
Re: power windows
Most newer GM,Ford and Chryslers use a regualtor assembly which the plastic track is plastic which break like I mentioned
Old 11-08-2009, 02:20 PM   #5
joe110860
Re: power windows
I went and checked both tracks they do not seem to be broken. Thanks for you help.
Old 11-08-2009, 04:10 PM   #6
RIP
AF -Advisor
RIP's Avatar
RIP Normal reputation
Re: power windows
Only "fuses" in the system are two PTC circuit breakers on the junction block. Won't be one of those because if either pops you'll have problems with all windows. That plus they should reset themselves as they cool eliminates them. Only thing common to both windows is the switch panel which you've changed. One trick you can try is to hold the switch up or down and slam the door at the same time.
I would remove either door trim panel and the vapor barrier then disconnect the window motor connector and check for voltage with the switch thrown. If it's there change the regulator assembly.
The window tracks are metal. The guides that run up and down the tracks are plastic. The window is attached to the tracks by plastic guides.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
RIP is online now   Reply With Quote
Old 11-13-2009, 02:13 AM   #7
hundahunta
hundahunta Normal reputation
Re: power windows
remove the door panel, hold with switch in the down position and pound on the window regulator motor..
hundahunta is offline   Reply With Quote
Bookmarks
Google
Web AF
