Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Cefiro/Maxima/I30/I35
Old 11-07-2009, 12:35 PM   #1
HUSTLEMANLV
HUSTLEMANLV Normal reputation
Unhappy whirling noise from pass side of engine
not sure what it is , a/c pump works but leaks oil , etc car doen't over heat and its a 1996 i30 . any ideas what it is
HUSTLEMANLV is offline   Reply With Quote
Old 11-08-2009, 08:31 AM   #2
Nahkapohjola
Nahkapohjola's Avatar
Nahkapohjola Normal reputation
Re: whirling noise from pass side of engine
Mileage?
Whats down there: Loose or bad belt, pwr steering pump, alternator, water pump.
Check in that order. Noise (bad bearing etc) can be located with a stethoscope; buy one from car accessory shop, maybe 10$ ...
Maxima INFO; goto http://www.cardomain.com/ride/748507
Car Electronics http://www.cardomain.com/ride/748507/14
Nahkapohjola is offline   Reply With Quote
Old 11-09-2009, 02:32 PM   #3
HUSTLEMANLV
223k belts new and tight , trying to see if its A/C pump or alt
Old 11-10-2009, 02:21 AM   #4
Nahkapohjola
Hmm. This started after getting new belt(s)?
...if so, then:
- belt is the noisy part; only replacement to another brand name helps
- its too tight. Try loosening a bit
With that mileage its hi time for some bearings to fail. Decide how long youre gonna live with this car. Then check out the vehicle and figure out all new parts needed for that 'trip': alt, A/C compressor, pwr steering pump, waterpump, shocks, exhaust, rust etc.... Calculate if all is worth for those years you plan to keep it. Next buy the parts or swap the car for another one... btw, excel sheet here is a wonderful tool.
Old 11-17-2009, 09:05 AM   #5
HUSTLEMANLV
Red face Re: whirling noise from pass side of engine
it's the a/c pump, when i turn the pump on it stops, guess it's time to swap out the bearing or spray some wd-40 etc on the bearing, car was driven thru a clay and sand pit sooooooo, damn, but thanks for the help
Bookmarks
Google
Web AF
