Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 11-05-2009, 12:47 PM   #1
exalteduser
exalteduser Normal reputation
Gas Smell
Recently changed fuel pump. after that was done i smelled gas (vapor), but i figured it might have spilled a little here or there. but its been 2 months maybe and it still smalles like gas when you walk by.
all 3 lines are connected on top, the rubber one didnt have clamps and was old hose could this be the smell origin?
94 4.3 4x4 blazer
with the multi port injection or w/e its called
exalteduser is offline   Reply With Quote
Old 11-05-2009, 05:01 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Re: Gas Smell
Fuel odor can come from any number of areas: Loose or cracked fuel vapor line, purge canister, purge canister vent valve, a poor sealing fuel pump "O" ring, fuel filler neck, fuel cap, leaky fuel tank, fuel pressure or return line, fuel pressure regulator, fuel injector, or the lines, commonly referred to as "nut kit", inside the plenum of your CMFI engine. Visually check each item closely as it doesn't take much of a leak for you to notice an odor.
old_master is offline   Reply With Quote
Old 11-07-2009, 05:20 PM   #3
exalteduser
Re: Gas Smell
the smell is definately at the rear of the vehicle near the tank, it has to be that 3rd vent line or the fill hose, i will start there.
Old 11-07-2009, 05:35 PM   #4
old_master
Advisor/Moderator
old_master's Avatar
Re: Gas Smell
Good luck and please post your results. If you have questions, just ask.
Old 11-09-2009, 04:04 PM   #5
Emmitt101
Emmitt101 Normal reputation
Re: Gas Smell
Check the hose near the front of the tank. Hooks to a sensor I think. Replaced my pump and broke the sensor without realizing it and the gas smell was terrible. You may have snapped out the connection like I did.
Jeff Isley
Emmitt101 is offline   Reply With Quote
Old 11-18-2009, 11:31 PM   #6
84hurst
84hurst Normal reputation
Re: Gas Smell
Common problem. Start at the tank. Just above the seam where the two parts of the tank are welded together salt can collect and cause a rust hole. I've gone through 2 tanks on my 94 jimmy. You don't even have to completely drop the tank. Take off the plastic cover (9 13mm bolts) and the 2 tank straps (18mm) towards the back of the truck and the tank should drop down enough for you to inspect the entire back of the tank. It should be fairly easy to see the hole if there is one. A small leak can be repaired (but don't use the gas tank repair kit found at the local parts store, use jb weld) but a larger hole, 1/4 in or bigger will require tank replacement. Good luck with the repair and let us know how it goes.
84hurst is offline   Reply With Quote
Bookmarks
Google
Web AF
