Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 11-02-2009, 07:04 AM   #1
whazoo
whazoo Normal reputation
Exclamation 97 4WD Starting problem
Hey all, My jimmy wont start, I have a new battery fully charged.
When I turn the key all lights come on, I hear the fuel pump doing its thing
but nothing when I roll to the start position, No Clicks no lug no nothing.
I tried to mess with the shifter to no avail I am at a loss here.
Any help would be appreciated.
Thanks
whazoo is offline   Reply With Quote
Old 11-02-2009, 08:52 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: 97 4WD Starting problem
Thanks
97 is a bad year on ign switches.
What engine and transmission.
Is the starter getting 12 volt start signal on purple wire to starter solenoid?
That signal has to come from ign key in start position and go threw neutral saftey switch and start fuse and starter relay.
To check starter.
I would start by jumping 12 volts to starter purple solenoid wire.
Does that fire up the starter?
MT
MT-2500 is offline   Reply With Quote
Old 11-02-2009, 01:15 PM   #3
whazoo
Hi thanks for the reply
its a 4.3L SFI with auto trans
4WD
I will try to get power to the purple wire and see what happens
thanks again
Old 11-02-2009, 01:49 PM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
4WD
thanks again
You are welcome and let us know how it goes.
MT
Old 11-02-2009, 06:43 PM   #5
whazoo
I tried to get voltage to the solonoid (tight fit) there are three terminals nothing purple.
There is two big lugs and a small one all black wires.
I assume the purple is the smaller of the wires.
I put a test light on the smaller wire and got nothing when the wife tried to roll it over.
I then remembered my old way of starting the shovelhead when the switch/button went bad, I jumped between the two larger lugs... nothing
sparked ok but no turning over nada from the starter. So I am a loss to what to try next.
Any advice?
Thanks again
Ps. Looking thu the flap behind the wheel, If you can picture a delta or triangle
At the top is the smaller wire and at the two base parts there are bigger wires..
Old 11-02-2009, 06:47 PM   #6
MT-2500
AF - Advisor
MT-2500's Avatar
Any advice?
Thanks again
If starter will not crank jumping at solenoid your starter is bad or no battery power to it.
MT
Old 11-02-2009, 06:51 PM   #7
MT-2500
AF - Advisor
MT-2500's Avatar
Starter solenoid start wire should be a purple wire.
MT
Old 11-05-2009, 06:51 AM   #8
whazoo
Re: 97 4WD Starting problem (Solved)
yep was the starter! Thanks for the replies and help!
Old 11-05-2009, 08:02 AM   #9
MT-2500
AF - Advisor
MT-2500's Avatar
You are welcome and thanks for posting back fix.
MT
Bookmarks
Google
Web AF
