Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 10-31-2009, 02:27 PM   #1
robbonner
robbonner Normal reputation
1988 voyager SE 4 cyl
How do I pull the codes from my 88' plymouth Voyager SE 4 cyl.?
robbonner is offline   Reply With Quote
Old 10-31-2009, 08:25 PM   #2
tempfixit
tempfixit Normal reputation
Re: 1988 voyager SE 4 cyl
Try the key dance: keyon/off, on/off. on within 5 seconds without starting engine and you should see the CEL flash (example: flash pause flash flash means code 12).
Let us know the code numbers:
Also here is a site with the how to retrieve codes and code definitons:
http://www.allpar.com/fix/80s-codes.html
hope this helps
tempfixit is offline   Reply With Quote
Old 10-31-2009, 11:41 PM   #3
robbonner
hope this helps
1 flash, 1 flash, 2 flashes, 3 flashes, 7 flashes, 5 flashes, 5 flashes
Thank you again for the info I sure hope this fixes it thanks again Rob
Old 11-01-2009, 01:28 AM   #4
tempfixit
Can you give us the problem of the vehicle and it symptoms??
Not sure what the codes are: possibly 11, 12. 23, 37 and 55: Redo the key dance and watch closely for the flashing cel sequences. flash pause flash means code 11. There is a pause between each code sequence.
The more information you can give us the better someone can help.
Old 11-01-2009, 11:57 AM   #5
robbonner
I was driving on the freeway and it suddenly died. It cranks but wont start. I've replaced the fuel pump , the coil, the ASD (auto shut down sylinoid), and jumpered a hot (+) from the the battery to the coil (+) but it still is not getting spark to the distributor.
Old 11-01-2009, 05:15 PM   #6
tempfixit
Which 4 cly engine do you have, 2.2, 2.5, or 2.6????
Have you removed the distributor cap and watched for rotation of the distributor rotor??? Hae you checked compression???
Sounds to me like either the timing belt or chain has broken, depending on which engine you have.
How many miles on engine???
Old 11-01-2009, 05:30 PM   #7
robbonner
Yep!!! Thats what it is alright... Thank you very much for guiding me through this and reminding me of my ignorance.... By the way, not that it matters anymore it's got 200,000 mi on it..... Any body want to buy a Van?! ha ha ha Thanks again Rob
Bookmarks
Google
Web AF
