Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 10-25-2009, 10:40 PM   #1
smartd
smartd Normal reputation
05 Caravan hits "wall" at 3500rpm
2005 Caravan SXT. Engine light on could not retrieve a code.
Works fine but hits "wall" at 3500 rpm, shudders.
Lifting off gas bringing rpms below 3500,... works fine again.
Runs fine as long as I keep eye on RPMs.
Any thoughts?
smartd is offline   Reply With Quote
Old 10-26-2009, 02:42 AM   #2
RIP
AF -Advisor
RIP's Avatar
RIP Normal reputation
Re: 05 Caravan hits "wall" at 3500rpm
You can check for codes using a scanner or the key dance. Try both. I would suspect either a fuel or timing issue. Maybe a pump on it's way out that can't handle high demand or a ckp sensor or harness issue. If you can get a real time scanner you may crack this.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
RIP is online now   Reply With Quote
Old 10-26-2009, 10:21 PM   #3
smartd
Thank you, gives me a place to start.
Old 10-28-2009, 10:43 AM   #4
Alphabravo
Alphabravo Normal reputation
Could be something as simple as restricted intake airflow. The exact same thing happened to me once. Try running it without the air filter and see what it does. If it runs good then you know it's time for a new one.
Good luck.
Alphabravo is offline   Reply With Quote
Old 10-30-2009, 07:38 PM   #5
warrenoutrides
warrenoutrides Normal reputation
my bet is on a partially plugged cat converter. mine hit wall ~3000rpm.
warrenoutrides is offline   Reply With Quote
Old 11-02-2009, 10:16 AM   #6
smartd
Good luck.
Thanks, I did this, no such luck.
Old 11-02-2009, 10:17 AM   #7
smartd
Using the on-off, on-off method, I got the code P0016 Cruise. Any thoughts?
Thanks.
Old 11-02-2009, 10:31 AM   #8
Alphabravo
Maybe it's the cat, then as Warrenoutrides suggested. have someone rev it up while you hold your hand near the exhaust and feel the output. obviously, don't touch the exhaust if it's hot. you may have to compare to a good car to notice any difference in the airflow.
Old 11-06-2009, 11:15 PM   #9
hundahunta
hundahunta Normal reputation
p0016 cam and crank timing misalignment....95% broken flexplate....
hundahunta is offline   Reply With Quote
Old 11-07-2009, 01:32 AM   #10
RIP
AF -Advisor
RIP's Avatar
Have to agree on the probable flexplate. I've been seeing these pop up with regularity lately. You can remove the inspection panel on the transmission and inspect it. This is probably the post that taught me about them relative to the P0016 code: http://forum.chryslerminivan.net/showthread.php?t=10581
Unread 11-27-2009, 11:22 PM   #11
smartd
Yep, it was the flexplate.
I wonder if garage would have found it on their own or only after lots of other fixes had been tried.
Codes etc. pointed to crankshaft.
The friendly experts on this forum pinpointed the similarities.
Of course the part itself is rather inexpensive but the book called for 6 hours of labour, so in the end it was a healthy sized bill to fix.
Thanks to everyone who commented on original post.
Unread 11-27-2009, 11:31 PM   #12
hundahunta
great to hear it's fixed....I've seen and heard of people replacing pcm's, sensors, engine harnesses, cam gears, timing chains etc....from this code...
Bookmarks
Google
Web AF
