| Latest | 0 Rplys |
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
10-21-2009, 12:01 PM | #1 | |
Put car on computer.
Went to Auto zone and had them put my 95 rs on there computer cause service light was on. Some said its because I run without a cat. So i just wanted to check. With amaze this is what came up.
Idle air control motor circuit Problem cause Open or short circuit condition Poor electrical connection Failed IAC valve Heated oxygen sensor - bank 1 sensor 1 (ho2s11) heated proformace Problem caused open or short circuit condition Poor electrical connection Faulty ho2s11 (bank sensor 1) Timing belt skipped 1 tooth or more Problem caused Jumped timing belt Loose camshaft or crankshaft position sensor Wow..lol dont even know where to start. Me and my buddy rebuilt the engine and knew the timing was off. Have plans on fixing it this weekend. But the other 2 I am lost on. |
10-21-2009, 12:47 PM | #2 | |
Dave is THAT guy
Re: Put car on computer.
Replacing the front O2 and the IAC is where you start.
Or test at least test out the IAC as shwon in the manual to make sure it is relly defective. If not, clean and reinstall.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
10-21-2009, 03:23 PM | #3 | |
Holset powered 420a
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
10-22-2009, 06:13 AM | #4 | ||
And are we talking about the downstream O2 sensor? Cause i think it runs to the catalytic converter which I don't have. Or does it run to the exhuast manafold? |
10-22-2009, 08:42 AM | #5 | |
Dave is THAT guy
Bank 1 sensor 1 is the O2 right off the turbo in the O2 housing. I forget if your car is turbo or not. If not, it's in the downpipe.
And yes a bad/faulty/dirty IAC will make the car idle funny, considering that's its job, is to make the car idle properly. A bad O2 will also do the same
10-22-2009, 11:08 AM | #6 | |
Holset powered 420a
Dave he has an RS. The O2 will be in the DP, replace it and see if the code goes away. It should be replaced every 100k if not before so Im sure it time for a new one. The IAC controls your idle so you cant 'set' your idle speed. The ECU is just going to adjust the IAC till it gets it back where it wants it. Some times codes will randomly get thrown and the sensor may still be good. Usually what I do it clear the codes and if it comes back then I start testing it to see if it needs to be replaced or not.
10-22-2009, 10:50 PM | #7 | |
IM going to buy the OS thursday. On the trottle body there is a type of bolt that let me ajust the idle using a star wrench. Unless I ajusted the wrong thing, but it did change my idle from 1500 to 1000 after I bought the car. Sorry for all the questions or not understanding, still new to Mitsubishi.
10-23-2009, 09:02 AM | #8 | ||
Dave is THAT guy
10-23-2009, 07:34 PM | #9 | ||
10-24-2009, 12:39 PM | #10 | |
Holset powered 420a
Someone may have adjusted it before and set it wrong. Its only there to keep the throttle plate from going all the way back, if it wasn't there or adjusted right the throttle plate may stick a little bit
10-30-2009, 09:39 PM | #11 | |
All problems worked out fine. Fixed the timing tonight, put a new o2 in yesterday. Getting new IAC tomorrow cause it was tested and was told to just buy a new one.
I put it on the computer and the only thing that was bad was the IAC. I can tell a differance after fixing the timing. Alot more pickup. Thanx for all the help |
