ABS service light cycles on/off?
2000 Astro RWD
The brake warning light keeps coming on periodically, sometimes with the first use of the brakes, sometimes after driving a bit longer. And then it goes off when the van is shut down, and upon starting again no light. Then on again, etc.
One mechanic couldn't find a brake code in the system error file, but suggested improper bleeding or lack of bleeding could be a possibility.
Any ideas?
The brakes work fine, the front was redone 10,000 m. ago and I keep checking the fluid level; it's fine.
