Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Cefiro/Maxima/I30/I35
Old 10-19-2009, 10:02 PM   #1
kurtwray
kurtwray Normal reputation
Exclamation nissan 89 maxima
Tries to start but wont. have replaced plugs,cap,coil,wires.Could it be a injector?
kurtwray is offline   Reply With Quote
Old 10-20-2009, 02:51 AM   #2
Nahkapohjola
Nahkapohjola's Avatar
Nahkapohjola Normal reputation
Re: nissan 89 maxima
Can be - but I'd put injectors on 'position 31' on the suspect list.
Check batt voltage. Make sure also ECU gets ground and +12.5V. See link below.
First and easy tst: try unplugging MAF. Shorted MAF can 'kill' engine. After unplugging it will start in safemode - if...
See also for campos signal from distributor (on my CDomain page 9 & 10.)
Note that long cranking (nostart) will get plugs wet as all injectors pump simultaneously. Plugs have to be cleaned or must have long dry-waiting period or crank-dry with disconnected injectors.
If belt jumps, engine cranks and about starts - but will not. Check the belt and its tightness. WHEN was it replaced? Should be once in 5 yrs 60k miles...
Pls tell how it goes.
Maxima INFO; goto http://www.cardomain.com/ride/748507
Car Electronics http://www.cardomain.com/ride/748507/14
Nahkapohjola is offline   Reply With Quote
Bookmarks
Google
Web AF
