Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Cefiro/Maxima/I30/I35
Old 10-10-2009, 02:53 PM   #1
rubs
rubs Normal reputation
thermostat issue
Hi,
I recently noticed that if the outside temp is around 50 and I set the thermostat at 70 it still blow cool air and only after i move the thermostat >80 that it start blowing hot air that was expected since i checked with external themostat and car temp was cold. This only happens in winter and in summer it works fine and correctly operate the A/C and keep the car temp as what is set in thermostat. what can be the possible issue?
Thanks
--rubs
rubs is offline   Reply With Quote
Old 10-18-2009, 07:34 AM   #2
Nahkapohjola
Nahkapohjola's Avatar
Nahkapohjola Normal reputation
Re: thermostat issue
Originally Posted by rubs View Post
Hi,
Thanks
--rubs
...w/o car history one could only guess between a squirrel nest inside the heater and a ctrl wiring contact problem, latter most common.
First and simplest: Is the coolant liquid level ok? Air bubbles thoroughly bleeded out?
I quess the problem could be in getting heated coolant flow started through the heater core.
Check this & links http://www.cardomain.com/ride/748507/7
Check also vacuum (=power) hosing to the heater valve; can be sticking due to myriad reasons (cracked hoses - inadequate vacuum).
Maxima INFO; goto http://www.cardomain.com/ride/748507
Car Electronics http://www.cardomain.com/ride/748507/14
Nahkapohjola is offline   Reply With Quote
Bookmarks
Google
Web AF
