Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 10-07-2009, 06:05 PM   #1
allenprimo913
allenprimo913 Normal reputation
1998 Ply Voyager 1,3 , 5 spark plugs
i need to know how to replace the inside 3 spark plugs on my voyager minivan, i can see # 5 but not much room, # 1 & # 3 are the ones that i can not access too.
i replace the 2,4 & 6 because they are outside, can somebody help whats the procedure to get access to them, i read you have to take the serpentine belt, the alternator , i can do that but what else to take
thanks for the help
allenprimo913 is offline   Reply With Quote
Old 10-08-2009, 11:00 PM   #2
plymouthsrock
plymouthsrock Normal reputation
Re: 1998 Ply Voyager 1,3 , 5 spark plugs
Engine? On my 3.8, I do the rear plugs from underneath the car.
plymouthsrock is offline   Reply With Quote
Old 10-09-2009, 12:21 AM   #3
allenprimo913
REALLY, do you have to jack the van, its going to be hard going underneath, isnt it?
Old 10-09-2009, 01:28 AM   #4
The_Mechanic_33
The_Mechanic_33's Avatar
The_Mechanic_33 Normal reputation
I also do them from under the vehicle but I have a hoist and it takes me about 15 mins.
You can remove the wiper arms and cowl from up top also,there are many posts here and on google.
htthttp://www.google.com/search?hl=e...f&oq=&aqi=p://
Remove the air intake resonator from the throttle body and air cleaner assembly.
referring to a (bracket) at the rear end of the intake manifold which is strut-like in that it connects the rear surface of the cylinder head to the intake manifold plenum, near spark plug #5. It's purpose is to mechanically support that end of the intake manifold.
YOU HAVE A PM
The_Mechanic_33 is offline   Reply With Quote
Old 10-17-2009, 07:37 PM   #5
Alphabravo
Alphabravo Normal reputation
I took the wiper tub off. It's a lot easier than it sounds. While you are there, if your O2 sensor is old you may want to replace it too.
Be sure to use copper anti-seize on the plugs, not silver. I heard silver kills the O2 sensors. Appearantly, if some gets into the combustion chamber and burns it releases a chemical that kills them.
Alphabravo is offline   Reply With Quote
Old 11-11-2009, 05:47 PM   #6
allenprimo913
easiest way is to unbolt your alternator and push back for number 1
unbolt bracket that holds the intake manifold sing away for # 3& 5
piece of cake
Old 11-12-2009, 02:10 AM   #7
RIP
AF -Advisor
RIP's Avatar
RIP Normal reputation
Piece of cake until you snap or spin a bolt or spend hours troubleshooting a problem induced by the disassembly. You avoid that by going from underneath. Takes an hour for all six.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
RIP is offline   Reply With Quote
Old 11-16-2009, 04:43 PM   #8
Spit
Spit Normal reputation
I've done mine from underneath (97 GV 3.3 engine184,000 miles) on several occasions. You need a long extension 30 -36 inch and a flex knuckle If this is the 1st time you are changings them, it really helps if you can spray some WD40 on to the base of the plugs & let it penetrate for awhile. The original plugs get set up pretty well and breaking them loose can be hard.
Spit
Spit is offline   Reply With Quote
Bookmarks
Google
Web AF
