Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > ES300/ES330/Windom
Old 10-06-2009, 12:41 PM   #1
barnold37
barnold37 Normal reputation
Question '93 Lexus ES300 Fuel in Exhaust/Runs Rough
I just bought a '93 Lexus ES300. It runs rough most of the time with raw fuel and white vapor comming from the exhaust. Occasionally it runs well with none of those symptoms, but that doesn't last long. The previous owner replaced the pre-injector and the #6 injector. He also replaced the ECM with a junkyard unit from a cross-referenced Camry. These repairs made no difference, and the pre-injector has to remain unplugged to keep massive amounts of fuel from pouring out the tailpipe. There is no significant water loss from the radiator, no water in the oil and the engine does not overheat. I'm planning on running a compression check this weekend to rule out the head gasket. Can a head gasket be bad without any of these other symptoms? Is it possible I have another bad ECM and/or injectors? If anyone has any experience or knowledge of something like this, there info would be greatly appreciated.
barnold37 is offline   Reply With Quote
Old 10-06-2009, 09:14 PM   #2
rhandwor
rhandwor Normal reputation
Re: '93 Lexus ES300 Fuel in Exhaust/Runs Rough
I would check the fuel pressure a leaking pressure regulator will allow excessive fuel into the engine.
Pull the vacuum hose for this regulator if it has fuel in it replace the regulator. They can fail other ways but this is a common problem of a rich running engine.
rhandwor is offline   Reply With Quote
Old 10-07-2009, 03:03 PM   #3
barnold37
Smile Re: '93 Lexus ES300 Fuel in Exhaust/Runs Rough
Thanks! I will check the pressure regulator. I am not very hopeful, though, as that would be WAY to easy! I do appreciate any ideas, however, and will certainly check it.
Bookmarks
Google
Web AF
