Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 10-05-2009, 06:13 PM   #1
slimecoat
slimecoat Normal reputation
Help with error codes
I have a chevy astro 2002 with 140K. I did a tune up after the check engine light went on. The tune-up consisted of sparkplugs, wires, fuel filter, rotor, distributer cap, air filter and fuel injector fuel treatment. The vehicle is now running worse. It misses really bad at idle. Here are the error codes
02 sensor heater
Injector circuit open
Random multiple misfire
Evap. Emission control system range
What does all this mean? Why did this all happen at once?
Help is greatly appreciated.
Thank
slimecoat is offline   Reply With Quote
Old 10-10-2009, 11:46 AM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
Re: Help with error codes
Not in any particular order:
What it means is that something changed to cause the PCM to think that an injector circuit is open. That could be a failed injector solenoid, poor connection, or failing PCM.
Failures don’t often occur gradually.
While a tune up is not a bad idea, the parts you replaced did not address the failure (obviously). What you did is tantamount to replacing a headlight bulb in an effort to repair a flat tire.
If there is a failed injector, liquid fuel injector treatment is not going to rewind an open injector solenoid coil, nor repair a failed injector pod electrical connector on the CPSI unit. You need to diagnose the problem with the hints given by the PCM and identify the cause.
That would be a symptom of a failed injector or incorrect mixture.
A failed injector would cause a misfire. A failing injector pod connector could cause a random (not specific to a particular cylinder) misfire.
02 sensor heater
These may be unrelated, or may be indicative of an electrical system connection problem related to all the symptoms. You need to study the schematics for the powertrain control and determine if a single connector or device is common to all these circuits.
Blue Bowtie is offline   Reply With Quote
Bookmarks
Google
Web AF
