Become a fan of Igor Sushko - Racecar Driver
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Thread Tools Search this Thread
Old 09-30-2009, 12:23 PM   #1
04cavalier
Need some opinions on power adders
I have an 04 cavalier with the 2.2l ecotec. I want to know what would be the best way to get horsepower out of it without haveing to replace internal engine parts. Im on a tight budget.
04cavalier is offline   Reply With Quote
Old 10-07-2009, 05:00 PM   #2
J-Ri
J-Ri's Avatar
Re: Need some opinions on power adders
The most they can handle with all stock internals is about 250HP. From what I've read, GM tested them with a single stage shot of N20, which goes from 145HP (stock) to 250HP instantly (or as close to instantly as you can get). A bit harder on an engine that gradually building boost. But to be safe, stay at or below 250 HP. That's about what mine has, and believe me, it's plenty for such a light car
Now, another thing to consider... if you're on a tight budget, why are you puting money into a car's performance? Save up and once you can afford it, just go all out and do it right. Everything is more expensive when you have more power. You might have to buy a higher grade of gas, you'll use more gas to go the same distance, it's much easier to get speeding tickets.
If you're going to do it anyway, the "best" way will depend on what you want it for. N20 is by far the cheapest initially, but you have to refill the tank. I think they say one $60 tank lasts for 4 quarter-mile runs with a 100-shot. Gets real expensive real fast, plus you only have a mile of 250HP and after that you're back to 145HP. I'd spend $120 a day just driving to and from work
I'd go with either a super- or turbo-charger. A few months ago Sumit Racing still had some GMPP ones left, not sure now. Very easy to install, took me about 7 hours to do it... If you can read you can do it. If you go that route, add $900 to the cost... I'll explain why if you go with that supercharger. The downside to superchargers is that they heat the air more before it enters the engine, thereby limiting the horsepower that can be gained. Not an issue if you want to stick to a stock engine.
If you aren't upgrading the engine, there's no reason to go with a turbo, unless you want to eventually upgrade the engine. They're more complicated, require much more work to install, and require 30-60 seconds of idling before shuting them off.
What I meant when I said "add $900 to the cost" above, was for HP tuners... Another option is just tuning it with HP Tuners. Check out their site for accurate info, but if I remember right just by tuning an LS-1 engine properly, you can get 150 HP more out if it. They're about 2.5 times bigger than the ecotec, so 60HP might be possible from an ecotec doing nothing but tuning it. If you go this route you'll also need a wideband AFR gauge. You might want to do this first, because if you add on anything else, you'll want to re-tune the PCM. Even changing the intake or exhaust will benefit from tuning.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
Old 10-08-2009, 04:18 PM   #3
04cavalier
I plan on rebiulding th engine next winter the car already has an adaquet shot of NOS but i would like to add a turbo, but the only one i can find is from han racecraft and its $3,000, thats a little high for me and i dont want to take the risk of an Ebay turbo kit, but i will check on the supercharger. right now im wanting more of the little things to add on.
Old 10-16-2009, 04:25 PM   #4
J-Ri
J-Ri's Avatar
You'll spend more than $3000 for the supercharger, the price went way up after GMPP discontinued them. The only reasons I went with the supercharger are that I don't plan on going past 250 HP (just wanted some power when I wanted it, not for racing) , I had very little knowledge of forced induction at that time, and I was installing it on my only [practical to drive] vehicle and I didn't want to drive my offroading truck 30 miles a day to work for weeks while I figured out how to install the turbo.
Old 10-22-2009, 11:05 PM   #5
Classicrocjunkie
Lifted GMT-360!
Classicrocjunkie's Avatar
Send a message via AIM to Classicrocjunkie
.... and I don't have any more supercharger kits to sell under $3k either. Lol...
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Classicrocjunkie is offline   Reply With Quote
Bookmarks
Search this Thread:
Automotive Forums .com - Car Forums - Privacy Statement - Top
Powered by Searchlight © 2013 Axivo Inc.
