Re: 2000 Astro fuel problems
We put a new Delphi pump in my 2001 Astro project. This morning with the old pump, to review, before starting it read 52 psi. I primed it and got it running, and it ran at 52 psi. I drove it 50 miles to Pittsburgh and it ran fine with no problems. Needing to prime it is not a situation you can have faith in. Our mechanic friend says when he has to prime one of these 4.3L Chev V6s, he knows its the pump, as I learned on this forum.
We installed a new Delphi pump this time. The electrical connector on top of the pump is different and they supply a new plug. You need to cut off the old plug and splice the wires with crimp connectors. (I am not crazy about crimp connectors for something like this so I used sealant on the ends of the crimp couplers to keep out the weather.)
The engine fired right up with no priming. Shut it off and hooked up the gage. With the engine not running and turning on the ignition, the gage popped right up to 62psi and then almost as quick the gage dropped back to 58 psi. We shut it off and tried this several times and it repeated the same reading 62psi and then dropping back to 58psi. After starting engine the gage read a bit over 54psi and allowing for a bit of gage error, even with this industrial gage, that pretty much agrees with the Haynes manual which said 55psi. (Haynes is not 100% clear about running versus not running readings.)
Delphi said this pump has improvements, but who knows what they mean?
The 62psi dropping quickly to 58psi before you start the engine seemed different, but? Its fires right up and runs great now, so my brother is happy, and I think running better without the vibration is because of the new timing gears and chain. Declutch, I wanted to add these comments and my findings to your thread to help with your engine, and I tried to be as accurate and specific as possible. I hope my comments can be helpful, but more than one mechanic has told me they don't completely understand why you can prime some of these engines and they will run fine all day, until the next day of course.
Hope everyones comments help you, their comments helped me, and I thank them for that.
To finalize this thread, we put in the new Delphi fuel pump last sunday and the 2001 Astro has been running great since then. With the new pump, it started instantly without even giving it a second to refill the lines or whatever. I think we started it again just for the fun of it. Then we shut it down because I HAD TO SEE what the gage read with the new pump. With the rngine off and turning the ignition switch to on instantly gave a 62 psi reading and just as quick it dropped back and settled at 58 psi. We turned it off and on a few times to confirm this. After starting the running reading is 54+ psi. The gage needle is a bit passed 54 psi and actually could be 55 psi. The divisions on this industrial gage are 2 psi. 55 psi is what the Haynes manual said, but I don't remember what they say about running versus just turning the key to "ON"
The Delphi pump had a new electrical connector with it. I had to cut off and save the old connector, (who knows if it will be needed for another pump change??) and splice the vehicle pump wiring to the new connector.
The Delphi pump instructions said it is an improved design?, I hope that it is true and it lasts. The mechanic friend we know says that priming an engine like this is his test for checking the pumps when they don't start normally. If it starts with a prime and keep running, its the pump!
Thanks everyone for your help and input.
