Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Interior/Exterior/Appearance
Interior/Exterior/Appearance The place for all interior, exterior and general non-performance modifications.
Old 09-24-2009, 05:33 AM   #1
fp1529
fp1529 Normal reputation
Extended cab windows
I have a 1982 extended cab s-10. How do you remove the side fixed windows? I am planning on painting the cab and there is some rust around these windows.
fp1529 is offline   Reply With Quote
Old 09-24-2009, 11:33 AM   #2
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
Re: Extended cab windows
I thought that the extended cab windows were the swing-out type. If they are not, then you would have to cut the adhesive holding them in. Be careful to not damage the plastic edge trim around the window.
If they are swing-out style, then you can remove the pressed-in pin to disconnect the plastic lock lever and window and unscrew the retaining nut. It appears it will slide out of the slots for the hinges from the parts drawing here... http://www.lmctruck.com/icatalog/cst/full.aspx?Page=29
[EDIT] Just checked...both were offered. Shoulda done my research beforehand Changes are in italics.
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Old 09-24-2009, 07:08 PM   #3
fp1529
They are the fixed type. Do I have to remove the black rubber trim from the outer edge? If so what is the best way to do it without damaging them? And any more details would help. Thanks
Old 09-25-2009, 01:26 PM   #4
jdmccright
The RustBuster
jdmccright's Avatar
You'll need a windshield bead cutting tool with some tape wrapped around the bend to protect the plastic/rubber trim...or you could apply tape around the window edge. You should not need to remove the window's edge trim. You can also apply tape to the cab around the window to protect the edge.
If you have reservations, take the truck to your local window replacement shop and ask them to cut them out for a small fee. Good luck!
Current Garage:
Vehicle History:
1996 GMC Jimmy 4wd
1980 Yamaha XS400
Bookmarks
Google
Web AF
