| Latest | 0 Rplys |
09-16-2009, 08:51 AM | #1 | |
2000 GMC Jimmy SLT
Hi,
I just noticed that when I run the heat after running this vehicle for quite some time no heat comes out of the vents. Any ideas on what could cause this and if so how can I fix it? I did check the two lines running out of the firewall and they both are hot to the touch. Any help would be greatly appreciated.... |
09-16-2009, 02:54 PM | #2 | |
A990 racer
Re: 2000 GMC Jimmy SLT
Welcome to AF, will it get hot if the engine is speeded up? Any sign of sludge in the coolant or radiator?
09-16-2009, 08:35 PM | #3 | |
Time for a system flush, but be warned. I had similar issues and after flushing my system it took out the intake manifold gaskets, heater core and the rad. All very common issues on these trucks.
09-17-2009, 07:38 AM | #4 | |
A990 racer
A little quick on the system flush without more info, temp doors, and actuators may still be in the mix.
09-17-2009, 08:53 PM | #5 | |
i have a 2000 slt also and my problem was the heater core was clogged up
i had them back flush the heater core and then flushed the system and to be honest i couldnt believe how much heat i have now i had that done winter of 2008 and no problems with intake or anything else just a idea good luck Jeff |
09-17-2009, 09:10 PM | #6 | |
I don't mean to imply that a flush will definitely cause issues, I just know that it can and one should be prepared for it, especially with these trucks, lol.
